AutoCAD Forum
Exporting AutoCad file as either stp or parasolid
4 REPLIES 4
1380 Views, 4 Replies
I'm quite new to AutoCAD and designed a part but now am attempting to export the file as a format friendly to our 3d printer. Either a stp or parasolid is needed. I'm pretty stumped and have tried importing into inventor and than exporting but nothing seems to work. Any ideas?
4 REPLIES 4
john.vellek
Hi @Anonymous,
Can you share your file so I can see what might be happening?
If your data needs to be private or confidential, please email it directly to me at john.vellek@autodesk.com and please include a link to this thread in your email.
John Vellek
john.vellek
Hi @Anonymous,
Thanks for sharing your files with me via email.  I opened each of them in Fusion 360 and then saved them in STEP format.
Please try this workflow on your side. You can get a trial of Fusion 360 here.
John Vellek
in reply to: john.vellek
I'm having the same challenge. Did you open the .dwg file in Fusion 360 then export it as a .stp file? I'm not able to get Fusion to open a  3D .dwg.
Thank you
Mike
pendean
John is no longer at Autodesk, but that is what is wrote as the solution:
"..I opened each of them in Fusion 360 and then saved them in STEP format...."
>>>...I'm not able to get Fusion...<<<
If you are on subscription with your AutoCAD at Autodesk, you can install and use AutoCAD MECHANICAL for free to do it https://knowledge.autodesk.com/support/autocad-mechanical/learn-explore/caas/CloudHelp/cloudhelp/201...
Forma Design Contest
AutoCAD Beta
