I don't use CAD to create any layouts but i do use a DWF version of a CAD file to mark up for network drops and electrical outlets. With that being said, I sent a CAD file and i am trying to convert it to a DWF file since it will be easier for me to use. However, when i try to either export the CAD drawing into a DWF or plot the file into a DWF, only half of the file is actually converted into a DWF file. I have attached a file showing the CAD file and the results of the DWF converting. Any help would be greatly appreciated.
Solved by Alfred.NESWADBA. Go to Solution.
Hi and Welcome to AutoCAD Forum,
i think it's settings issue that must be fit . from plot dialog select Window from what to plot and select right and proper scale and check your drawing orientation ( Por. or Land. ) that meet your paper size .
Imad Habash
If I do the export option and change it to windows. I get the same result. See attached.
If I try the print plot option and choose "Windows". The Plot - Model window disappears.
So your DWFx sheet size is letter size, not A0 sheet size: that's also the default size of your pagsetup in your DWG file, and the default setting in your PLOT style table (which is also set to plot the DISPLAY, so if you are zoomed in wrong it doesn't work either).
I don't seem to have any issues 'exporting' or plotting to DWFx to show everything in your modelspace here as long as I ensure sheet size and what is getting plotted are addressed. Be careful if you use EXTENTS as you have floating items out there. See attached.
Consider using PREVIEW command in AutocAD before you ExportDWFx or plot to ensure you are going to get what you actually want.
Thanks for the replies ImadHabash and Pendean.
However, neither option has worked. I have tried each one multiple times without any success.
Pendean, when i open the files you have attached they are still missing 90% of the layout that is shown in the DWG file. I have attached some screenshots to show what i see when i open your files.
I am running TrueView 2018 and Design Review 2018. Is it possible the issue could be in either of these two pieces of software?
Your dwg-file has XRef's, but you have not uploaded them, so @pendean can only show in the DWF what he has got as DWG.
Could that be the difference? 😉
- alfred -
I don't normally work with a straight DWG file and didn't think about the xRef files. I have attached those files. So there some way they can be combined into the other files?
you have set some layers to "no-Plot", make them plotable and you see the referenced data also in the plot to dwf.
(also turn them on, which I already did in my screenshot)
- alfred -
