Export .stl file
Export .stl file
Hello all,
I am having some trouble exporting my AutoCAD .dwg file as .stl after exploding the model, deleting some parts and regrouping.
Before the modification of the model Export-other Formats - .stl always worked for me. Now I can not select my model any more for exportation. The group is found but is then filtered out.
Can you please tell me what I am doing wrong?
Thanks you!
Best
Kassandra
Replies (11)
Patchy
After exploding the model, what are the pars listed as? Are they solid 3d ?
Grouping doesn 't mean they must be solids, they can be anything.
john.vellek
Hi @Anonymous,
What version of AutoCAD are you using? (Type ABOUT at the command line). Is it possible to share a sample drawing that doesn't export to STL properly?
John Vellek
Thanks for your help.
The product version is N. 52.0.0 AutoCAD 2017.
It said and says "2D Drahtkörper" above my drawing.
@john.vellek: If I may sent you a copy of the file, I can show you a sample which does not convert properly.
john.vellek
HI @Anonymous,
Please first update your AutoCAD 2017. My version is N.402.0.0 AutoCAD 2017.1.2 Update. It appears that you are missing a bunch of updates.
Then, please send me your file at john.vellek@autodesk.com so I can take a look at it for you.
John Vellek
Alfred.NESWADBA
When you explode your model (damage it) you will get entity types that are not supported to be exported as STL objects.
Please keep in mind, exploding 3D-Solids breaks the complete structure, it's like disassemble an engine and throw the screws away, you won't get it working any more.
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2025
(not an Autodesk consultant)
I updated and it still does not work. I am afraid, that the exploding is the problem as  @Alfred.NESWADBA suggested. I now get the message "select solids or watertight meshes" instead of "select object" - a description which might not fit to my model any more and my model is deselected out of this reason.
Thank you @Alfred.NESWADBA, I guess this is the problem. Is there any other way to delete parts of my "grouped model" avoiding exploding?
Alfred.NESWADBA
You can use the boolean functions like _SUBTRACT to remove part of your 3D-Solid.
In case that are 3D-Solid parts that do not physically intersect and you want to split them into separate parts you can also use command _SOLIDEDIT ==> _BODY ==> option _SEPARATE.
- alfred -
Alfred NESWADBA
john.vellek
Hi @Anonymous,
You might consider using slice to split your model up.  I am still happy to look at your drawing if you would like to share.
John Vellek
john.vellek
Hi @KassandraRekilia,
You indicated in a private email that included your file (thank you) that you were trying to remove the screws from the model.   I made a quick video that shows my approach. I hope this works for you. If not, let me know why it doesn't solve the issue and I will try something else.
John Vellek
Thanks for your help, @john.vellek@Alfred.NESWADBA and @Patchy!
