AutoCAD Forum
Export .stl file
11 REPLIES 11
Message 1 of 12
1618 Views, 11 Replies
Export .stl file
Hello all,
I am having some trouble exporting my AutoCAD .dwg file as .stl after exploding the model, deleting some parts and regrouping.
Before the modification of the model Export-other Formats - .stl always worked for me. Now I can not select my model any more for exportation. The group is found but is then filtered out.
Can you please tell me what I am doing wrong?
Thanks you!
Best
Kassandra
Export .stl file
Hello all,
Thanks you!
Best
Kassandra
Tags (3)
11 REPLIES 11
Message 2 of 12
Patchy
Patchy
After exploding the model, what are the pars listed as? Are they solid 3d ?
Grouping doesn 't mean they must be solids, they can be anything.
Message 3 of 12
john.vellek
john.vellek
Hi @Anonymous,
What version of AutoCAD are you using? (Type ABOUT at the command line). Is it possible to share a sample drawing that doesn't export to STL properly?
John Vellek
Hi @Anonymous,
John Vellek
Message 4 of 12
in reply to: john.vellek
Thanks for your help.
The product version is N. 52.0.0 AutoCAD 2017.
It said and says "2D Drahtkörper" above my drawing.
@john.vellek: If I may sent you a copy of the file, I can show you a sample which does not convert properly.
Message 5 of 12
john.vellek
john.vellek
HI @Anonymous,
Please first update your AutoCAD 2017. My version is N.402.0.0 AutoCAD 2017.1.2 Update. It appears that you are missing a bunch of updates.
Then, please send me your file at john.vellek@autodesk.com so I can take a look at it for you.
John Vellek
HI @Anonymous,
John Vellek
Message 6 of 12
Alfred.NESWADBA
Alfred.NESWADBA
When you explode your model (damage it) you will get entity types that are not supported to be exported as STL objects.
Please keep in mind, exploding 3D-Solids breaks the complete structure, it's like disassemble an engine and throw the screws away, you won't get it working any more.
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2024
(not an Autodesk consultant)
- alfred -
Alfred NESWADBA
Message 7 of 12
I updated and it still does not work. I am afraid, that the exploding is the problem as  @Alfred.NESWADBA suggested. I now get the message "select solids or watertight meshes" instead of "select object" - a description which might not fit to my model any more and my model is deselected out of this reason.
Message 8 of 12
in reply to: Alfred.NESWADBA
Thank you @Alfred.NESWADBA, I guess this is the problem. Is there any other way to delete parts of my "grouped model" avoiding exploding?
Message 9 of 12
Alfred.NESWADBA
Alfred.NESWADBA
You can use the boolean functions like _SUBTRACT to remove part of your 3D-Solid.
In case that are 3D-Solid parts that do not physically intersect and you want to split them into separate parts you can also use command _SOLIDEDIT ==> _BODY ==> option _SEPARATE.
- alfred -
Alfred NESWADBA
- alfred -
Alfred NESWADBA
Message 10 of 12
john.vellek
john.vellek
Hi @Anonymous,
You might consider using slice to split your model up.  I am still happy to look at your drawing if you would like to share.
John Vellek
Hi @Anonymous,
John Vellek
Message 11 of 12
john.vellek
john.vellek
Hi @KassandraRekilia,
You indicated in a private email that included your file (thank you) that you were trying to remove the screws from the model.   I made a quick video that shows my approach. I hope this works for you. If not, let me know why it doesn't solve the issue and I will try something else.
John Vellek
John Vellek
Message 12 of 12
Thanks for your help, @john.vellek@Alfred.NESWADBA and @Patchy!
AutoCAD Inside the Factory
