Export rectangle polyline sizes
carl.coghill
carl.coghill
I need to get the size and quantity of the rectangle polylines contained on the "Decking" layer within the attached drawing. Ideally as an excel export.
I have tried DATAEXTRACT, the best that I can get from this is the total length of the polylines. The length and width of the rectangle both vary, therefore I cannot calculate size from the polyline length.
Also, the information I require is contained within TXT although over multiple entities. An alternative solution would be to export this information to excel.
Can anyone help?
AutoCAD 2016
Windows 7 Professional 64bit
Carl Coghill
Senior Designer
AutoCAD 2018
LinkedIn
carl.coghill
I have also tried the DATAEXTRACTION command on the TXT objects. I then get the tabled TXT as a list - not really useful.
Carl Coghill
Senior Designer
AutoCAD 2018
LinkedIn
Slawomir_
You should be able to select 'Area' property during step 4 of 8 Data Extraction. See attached image. Polylines doesn't need to be closed.
carl.coghill
Leon,
It is the lenght and width that I am looking for, not area.
Carl Coghill
Senior Designer
AutoCAD 2018
LinkedIn
Patchy
I don't know if this will help any.
carl.coghill
Patchy,
I have had a quick look, it appears to be what I am after.
How did you get the information?
Carl Coghill
Senior Designer
AutoCAD 2018
LinkedIn
Patchy
I use the autolisp to label the rectangles then Dataextraction to get the Text only in excel format.
Here is the link for the autolisp:
http://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/length-and-width-of-rectangle-as-text...
