At first, sorry for my bad english, I hope it would be understandable.
I'm beginner on Autocad and I try to learn by myself. I'm currently busy for some hours with a beginner problem, the situation is really simple:
I draw a circle (radius = 800 cm ) and a rectangle ( L=120cm, l=10 cm, those dimensions have to be constant so I have applied dimensions contraints). I would like to force the positionning of this rectangle on my circle: the rectangle must remain horizontal and its 2 upper corners must be ON the circle.
After that, another rectangle (with the same dimensions) will be drawed : the right upper corner must be coincident with the left upper corner of the first rectangle (so on the circle) and its left upper corner must also be on the circle. 2 other rectangles must be drawed following the same way (check my file in attachment).
Is there any way to apply a contraint to make sure that "this point must be on the circle" ? My final purpose is to change manually the radius of the circle (the rectangles however must remain the same) and that rectangles placed on this circle adjust their position depending on the circle radius.
I tried with varied ways (with temporary circles) to spot the exact point who rectangle corners are supposed to be and then using the "coincident" contraint, but it doesn't work ( apparently coincident contraint doesn't work with a corner and a intersection )
Thank you to tackle my problem ! My file is in attachment, I tried to put text to make your understanding easier.
Julien
