Export PDF to the same folder as the DWG
Message 1 of 10
I'm using LT 2019 and required to use Export PDF to output the finished documents.
At the moment, when I Export to PDF, Autocad tries to save the PDF in the folder for previously opened drawings and I have to manually locate the folder with the current drawing. Is there a setting to automatically export the PDF to the same folder as the drawing itself?
Using Publish (or similar methods) is not an option.
Replies (9)
Message 2 of 10
rkmcswain
I did read the last line, but I don't know if you consider "AutoPublish" to be a "similar method". It does contain an option to print to the current drawing folder.
Message 3 of 10
beyoungjr
Once you export a file type to a destination folder it should stick to that until your next AutoCAD session.  The first export will try to target a default location and typically needs focused where I prefer.  It almost never focuses where the actual drawing file is located so you would have to navigate at least once during that session of running AutoCAD.
Hope that helps,
Blaine
Blaine Young
Senior Engineering Technician, US Army
Message 4 of 10
maratovich
1. Export to PDF = print/publich to DWG To PDF.pc3
It is the same, not different.
2. Run script :
_Filedia
0
_-Export
_P
_A
C:\Users\Dima\Desktop\NewNameFile.pdf
_Filedia
1
Software development
Automatic creation layouts and viewport. Batch printing drawings from model.
www.kdmsoft.net
Message 5 of 10
That's the way it works now, which I hope to avoid. I'll open a drawing for one project, make changes, then move to the next project, and if I export the PDF it goes into the first project folder, not the current, which I what I want to avoid.
Message 6 of 10
It's not an option. Period. My boss has made that very, very clear.
Message 7 of 10
Didn't work - PDF went into the same folder as the previous drawing.
Message 8 of 10
beyoungjr
I can't recall it ever happening any different than how it does now.  It would be pretty cool if it did so but I haven't seen it over MANY versions/years.
Blaine Young
Message 9 of 10
I'll try it again on Monday with a fresh startup.
Message 10 of 10
jreidCDS28
Good Morning.
When I open Sheet Set for Project 1.
I set the output PDF file to print inside the same folder as Project 1 CAD files.
Works Great!
But I open Project 2.
I review the output folder for the PDF files and it reads the Project 1 CAD Files folder.
I change it to Project 2 folder. Works great.
Until I go back to Project 1 and now the output folder is Project 2.
How can I have it keep the locations of the individual Sheet Set files that are inside the CAD File Folders?
Thanks!!
