Export multiple layouts to dwg (model space) from multiple sheet files (dwg)
neil96VHF
Message 1 of 42
neil96VHF
Hi All,
Does anyone know of a workflow to export Autocad (paper space) layouts to dwg (model space) from multiple separate sheet dwg files?
The project is composed of multiple folders containing separate sheet files. The layouts show xref'd drawings from model space files contained in separate model folders. I can see how to export the layout from inside an individual sheet file but have been asked for model space versions of all of the layouts from all of the sheet files.
Im assuming this is only possible through a third party addon, any suggestions would be much appreciated 🙂
Replies (41)
Message 41 of 42
neil96VHF
Thank you all for the help, AutoScript seems to do the job, there are issues with the way the files are set up hence the way theyre looking once exported. This gives us a good starting point to tighten up our drawing conventions to work with the script. Many thanks @Ed__Jobe for the script, it does exactly what we need and thanks to @paullimapa for the suggestion of Autoscript. All the best, N
Message 42 of 42
paullimapa
Glad to have assisted…cheers!!!
Paul Li
IT Specialist
@The Office
