Dear Sir,
I am Rafeeq Working as Structural Draughtsman. I am using AutoCAD 2016 version.
I would like to get a solution for Exporting a Dwg file to Google Earth.
Is it possible by AutoCAD itself? If YES, Please describe me how I can do it ?
If NO, Let me know what kind kind of supporting software i have to use it ?
It will be appreciated your kind support regarding this matter. Thank you.
Solved by Murph_Map. Go to Solution.
Why export to Google Earth when you can bring in BING Maps into AutoCAD and save the images with the dwg.
Hello from France
Welcome to the Autodesk/AutoCAD forums !
1) In the past (until ACAD 2012), Autodesk had an optionnal plugin :
Google Earth plugin for ACAD 2008-2012 which can export 2D & 3D graphics to KML ...
BUT unfortunately Autodesk has discontinued this nice plugin !!
2) Today if you have not keep an old ACAD 2011/2012 with this old plugin you can't export KML/KMZ directly from ACAD !
Of course I kept it ... as many other french users ...
If you have ONE DWG to export and if it is not top-secret, I can do it for you !?
3) So you have to use NON Autodesk software ...
Regards, Patrice (I am not an Autodesk Advisor)
Patrice BRAUD
@Anonymous wrote:
Thank you Mr. Murph. I have tried it and it is working. Appreciated.
You're welcomed, glad to help.
hi Braudpat,
i have the same need but i dont have autocad
i have a dwg file that needs to be converted to googgle earth, thank you
please email me to
mm at kronos-ap.com
