Export Dwg file to google map
Dear Sir,
I am Rafeeq  Working as Structural Draughtsman. I am using AutoCAD 2016 version.
I would like to get a solution for Exporting a Dwg file to Google Earth.
Is it possible by AutoCAD itself? If YES, Please describe me how I can do it ?
If NO, Let me know what kind kind of supporting software i have to use it ?
It will be appreciated your kind support regarding this matter. Thank you.
Replies (8)
Patchy
Is it a supportive software for autocad?
No solution by autocad itself?
pendean
Community Legend
Community Legend
No.
Murph_Map
Why export to Google Earth when you can bring in BING Maps into AutoCAD and save the images with the dwg.
Murph
Supporting the troops daily.
braudpat
Hello from France
Welcome to the Autodesk/AutoCAD forums !
1) In the past (until ACAD 2012), Autodesk had an optionnal plugin :
Google Earth plugin for ACAD 2008-2012 which can export 2D & 3D graphics to KML ...
BUT unfortunately Autodesk has discontinued this nice plugin !!
2) Today if you have not keep an old ACAD 2011/2012 with this old plugin you can't export KML/KMZ directly from ACAD !
Of course I kept it ... as many other french users ...
If you have ONE DWG to export and if it is not top-secret, I can do it for you !?
3) So you have to use NON Autodesk software ...
Regards, Patrice (I am not an Autodesk Advisor)
Patrice ( Supporting Troops ) - Autodesk Expert Elite
If you are happy with my answer please mark "Accept as Solution" and if very happy please give me a Kudos (Felicitations) - Thanks
Patrice BRAUD
Thank you Mr. Murph. I have tried it and it is working. Appreciated.
Murph_Map
You're welcomed, glad to help.
Murph
hi Braudpat,
i have the same need but i dont have autocad
i have a dwg file that needs to be converted to googgle earth, thank you
please email me to
mm  at   kronos-ap.com
