Exploding Minsert blocks
kylei7449
Message 1 of 37
kylei7449
I've been searching for a routine to explode minserts but haven't found anything yet that works. However, this one did. It's a vlx that I found on another forum (sorry, don't remember which or I'd give the poster/author the credit)
Just copy it to your Support folder and load it ("AP"). Type "explodem" at the command line to run it. It first asks you to select the block; it then asks you if you want to explode? [No/Yes]  Enter No. Yep, enter no. (I know; I tried Yes but it wouldn't work...might be just me though cuz I'm a bit dyslexic; either that or the programmer may be?)
Worked for my situation. Give it a try.
Replies (36)
Message 21 of 37
Ed__Jobe
If you would like a single one-click command, I wrote something in C# that will do this.
        //  ExplodeMinsert
        /// <summary>
        /// ExplodeMinsert is a command that explodes a <c>MINSERT</c> entity.
        /// </summary>
        [CommandMethod("TID", "ExplodeMinsert", "ExplodeMinsert", CommandFlags.Modal)]
        public void ExplodeMinsert()
            // Ask user For old block name
            PromptEntityOptions PEO = new PromptEntityOptions("Select a MINSERT entity to explode: ");
            PEO.SetRejectMessage("You need to select a minsert: ");
            PEO.AddAllowedClass(typeof(MInsertBlock), true);
            PEO.AllowNone = false;
            PromptEntityResult PER = Active.Editor.GetEntity(PEO);
            try
                using (Transaction trans = Active.Database.TransactionManager.StartTransaction())
                    MInsertBlock oMins = (MInsertBlock)trans.GetObject(PER.ObjectId, OpenMode.ForWrite);
                    oMins.ExplodeToOwnerSpace();
                    oMins.Erase();
                    trans.Commit();
            catch (Autodesk.AutoCAD.Runtime.Exception ex)
                //Throw Exception or ignore if user cancelled command.
                if (ex.ErrorStatus != ErrorStatus.NullObjectId)
                    MessageBox.Show("Error Occured in ExplodeMinsert command. " + ex.Message + ", " + ex.HelpLink, "ExplodeMinsert Error", MessageBoxButtons.OK, MessageBoxIcon.Error);
Ed
How to post your code.
Message 22 of 37
its works great .load the file and type explodem then give yes .
Message 23 of 37
ksreekumar
Greetings,
Thank you for the .vlx file worked perfectly to me.
Message 24 of 37
Thanks @Anonymous .
Your solution works like a charm. I'd vote this as the best solution if I could.
Message 25 of 37
Bro, it worked for me so i thank you so much. i really appreciate your help.
Message 26 of 37
1. Copy your minsert block to a blank file.
2. Export the drawing as .wmf (windows metafile)
3. Open a new empty drawing
4. Insert the .wmf file
5. The MINSERT BLOCK now appear as Block reference
6. Explode
7. Some entities may be lost but work with the drawing lines
Message 27 of 37
ksreekumar
Wow, this is amazing, thank you for the best idea....
Message 28 of 37
Select your object then write the command, FLATTEN then enter, then it will ask you remove hidden lines ?
write command : YES.
its now break but same time it will move automatically from its existing place and it size also will be change.
Message 29 of 37
use fllaten command and yes
Message 30 of 37
flatten command & yes
Message 31 of 37
Select your object and use FLATTEN command and ender, and and write command yes.
Message 32 of 37
Thanks a lot
it really works on my autocad 2012
Message 33 of 37
it works 100%
Message 34 of 37
yaxgaustria
This solution works, thanks
Message 35 of 37
ar683707
Observer
Observer
This worked great, thank you!
Message 36 of 37
surajkumarverma93
Community Visitor
Community Visitor
Ha Ha Ha😂😂
I have found the solution
Type a Command in Command line "FLATTEN" Enter
Select MInsert Block Enter
Type "Y" Enter and wait some second
BOOM BOOM Problem solve 😉
Thanks me Later🤗
If you have any other problem message to me
Message 37 of 37
Kent1Cooper
@surajkumarverma93 wrote:
.... I have found the solution
Type "Y" ....
[This was already suggested here five times, in Messages 18, 28, 29, 30 & 31.  Please read through a topic before replying, to avoid adding something completely redundant.]
Kent Cooper, AIA
