Existing hatch cannot change to solid
Message 1 of 22
I have a lot of existing hatch cannot change to solid.Please help.
Replies (21)
Message 2 of 22
Patchy
I see no problem ☺
Message 3 of 22
The other one cannot change
Message 4 of 22
I cannot find the problem
Message 5 of 22
pendean
Community Legend
Community Legend
Erase and replace it: it is the quicker fix. Seems to be broken somehow.
Message 6 of 22
But I have 10 cad file and each file have about 10000 hatch need change to solid.
Message 7 of 22
Patchy
Were they drawn with Autocad or converted from another program, I have never seen this pattern before.
Message 8 of 22
This is a custom pattern from the drawer.I need to change all of the pattern to solid.I think I find the problem.But I dont know how to fix it easy.
Message 9 of 22
Patchy
Post a worst one that has hundred of these hatches and let's see.
(I need 2007 version)
Message 10 of 22
2007 Version DWG
Message 11 of 22
Patchy
I need the one with thousands of them so I can test with autolisp.
Message 12 of 22
Yes.Please help me.
Message 13 of 22
Patchy
It might miss some
Message 14 of 22
s.borello
Just redraw it... it will be quicker for you.  Something seems to not be working on that lower hatch.
Message 15 of 22
I have 10 cad file and each file have about 10000 hatch need change to solid.Very slow.
Message 16 of 22
My file only have 319 objects and your file have 320 objects?
Message 17 of 22
Alfred.NESWADBA
When I play with your dwg  with these steps:
  • change the pattern type to predefined
  • then pattern name to SOLID
and run then _AUDIT ... AutoCAD shows this message:
Pass 1 100     objects auditedAcDbHatch(248)
   No Closed Hatch Boundary Loops
AcDbHatch(248)                    could not be repaired.  It will be Erased.
This means the hatch boundary seems to be defect.
So the options I see:
1) use a tool (or write one yourself) which goes through all these hatches, recreates the boundary, delete the hatch and create a new hatch, this one can then be SOLID.
2) (...not preferred, but if it's just for 1 plot) go the old way and change the pattern to e.g. predefined/ANSI31 and make the hatch dense enough so it looks like filled on your plot. But take care, that makes the display of this drawing slow.
The more important thing here is ... verify who is the creator of these hatches and inform them that the hatches are defect, otherwise they produce more and more defect drawings.
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
Message 18 of 22
parkr4st
a manual method
working with Drawing4(autoCAD2007)
three new layers, name one NewHatch
Layer 1 on & current  HatchGenerateBounds selected all the hatches  enter
QSelect  Polyline Closed = No
PropertyPallet  change the selected to layer2
Layer 1 off
DrywallType layer off
3 sets of open polylines left. make sure the intersections intersect
Boundary & pick  point inside the lines  enter
Layer 2 off
Layer 1 on  leaving a complete set of closed boundaries to hatch
Layer NewHatch Current & on and run the Hatch command on those closed polyline objects
DRYWALLTYPE1 on and qselect everything in that layer and  delete if you don't have any further use for it.
Message 19 of 22
I think your dwg is what I want but My poor english and cannot follow your step.Could you post a video for me to follow?Thank
Message 20 of 22
parkr4st
What is your preferred language?
