AutoCAD Forum
ADVICE: I need to view and edit CATIA files
4 REPLIES 4
1500 Views, 4 Replies
Hi there,
I'm working in a small business with sheets metal molds and our partners share with us files through CATIA. So, we are looking for a software which is able to open and then allows us to edit something. Is AutoCAD a solution? Or do you know some other programs that will help us?
Thank you
Hi there,
Thank you
4 REPLIES 4
imadHabash
imadHabash
kind off ... you can from IMPORT dialog insert those CATIA files .
Imad Habash
Imad Habash
in reply to: imadHabash
But I can also edit these files?
There's another autodesk program which will be better than autocad?
pendean
pendean
Community Legend
Community Legend
AutoCAD does not read/open CATIA files. You will need CATIA., or ask the CATIA file creators to save files down to a file format you can use with your software (or AutoCAD if you want to go there). But you are comparing apples to moon rocks here, you and your client (CATIA files sender) need to talk more and do some testing together.
CATIA viewers are everywhere https://www.google.com/search?q=catia+viewer
in reply to: pendean
ok, thank you
ok, thank you
AutoCAD Inside the Factory
