AutoCAD Forum
Exercise 7.1M Stop Plate
3 REPLIES 3
915 Views, 3 Replies
Hello, I need help in adding the dimensions 2xR and R by itself on the drawing. I understand it might be easy but I don't seem to find the command or directions to show them like that instead of providing me the actual radius.  I will provide my own drawing as well. Thanks!
Labels (3)
3 REPLIES 3
devitg
Hi @Anonymous For better understanding, and maybe get further help, please upload such sample.dwg
Patchy
Use TEXT command ☺
vinodkl
Hi @Anonymous
You can use the properties palette to override the dimension to suit your need.
Select the dimension and then press ctrl+1 which would open the properties palette. Now scroll down on the palette and you would see "text override" you can enter "R" or "2X R" over here 🙂
ವಿನೋದ್ ಕೆ ಎಲ್( System Design Engineer)
Likes is much appreciated if the information I have shared is helpful to you and/or others.
Please mark "Accept as Solution" if my reply resolves the issue or answers your question, to help others in the community.
AutoCAD Inside the Factory
