How to Print to Scale, for beginners that have read the directions already
TuesdayNightCo
Message 1 of 10
TuesdayNightCo
Hello forum! I'm about ready to cry blood here and would appreciate help with this very silly problem.
I have erratic scaling issues that I haven't been able to resolve via tutorials. I am (always) trying to print my landscape drawings at 1/4 scale on Arch D 36"x24" paper.
I draw at full scale (1:1) and my UNITS are set at Architectural.
While in a Layout tab, I follow this protocol:
Click on and delete the viewport.
"A" menu in right corner> Print>Print Setup>[click on the relevant plot name]>Modify>
[THEN]
Paper Size: Arch D
What to Plot: Layout
Scale: 1:1 [I've tried 1/4 and it shrinks or blows things up strangely -- no idea why] so that's 1" = 1 drawing unit
Plot Style and Plot Options are untouched. Orientation is at landscape.
>OK
[THEN]
Type VPORT>[choose Single]>[draw my viewport]>[click on my drawn viewport]>[go to bottom right ribbon]>[select the scale, which is usually a bunch of numbers that show the scale is adjusted to fit]>Scale: 1/4"=1'0".
Okay. Now. Tell me what the hippity-hoppin' hell I'm missing here. How can I be sure my scale is actually correct when I have two different viewports, apparently set for the same scale, are showing me views that are more, or less, zoomed-in than the other? I'm not accidentally scrolling while in the selected viewport, thus resetting my scale, so WHAT is happening and more importantly, WHY? WHYYYYYYYYYYYYYY
My attached drawing has Layout 1 and Layout 3 as my 24x36 printout (or 36x24 printout, not sure what the difference is since they ought to print the same). But they don't look the same and this is a problem I have with ACAD in general. I really need to not make costly mistakes by printing and finding out at the printer that the scale is off (which has happened). I need to KNOW this is right.
Replies (9)
Message 2 of 10
GrantsPirate
Nothing attached.  In the layout you will print at a 1:1 scale.  The viewports are set to the desired plotting scale.  As long as your layout title block is the correct size (if you are plotting to a 24x36 sheet then the title block will need to be approximately an inch smaller than that due to printer limitations, etc.) then plotting 1:1 will work fine.
GrantsPirate
Piping and Mech. Designer
EXPERT ELITE MEMBER
Always save a copy of the drawing before trying anything suggested here.
If something I wrote can be interpreted two ways, and one of the ways makes you sad or angry, I meant the other one.
Message 3 of 10
TuesdayNightCo
Attempt two on attachment.
Message 4 of 10
TuesdayNightCo
Hm. So it should work. But just. Sometimes doesn't.
Title blocks! Hah hah I should use those. Maybe it'd help me determine if something is off?
(The paper with the block already printed on them is what I use -- but it is expensive and hard to find.)
Message 5 of 10
SeeMSixty7
@TuesdayNightCo Scalers tend to trouble a lot of people. I wrote a series of Blog posts for this very subject. It's four parts, but if you read through it should answer all your questions or at least help you understand where the trouble might be that you are having.
Part1
http://www.seemsixty7.com/blog/2017/03/27/cad-basics-101-scale-factor-part-1/
Part2
http://www.seemsixty7.com/blog/2017/03/28/cad-basics-101-scale-factor-part-2/
Part3
http://www.seemsixty7.com/blog/2017/03/29/cad-basics-101-scale-factor-part-3/
Part4
http://www.seemsixty7.com/blog/2017/03/30/cad-basics-101-scales-part-4-paperspace/
Good luck and I hope that helps.
Message 6 of 10
TuesdayNightCo
Thank you, I'll do that! I'm desperate to understand what in the Sam Hill I'm doing.
Message 7 of 10
rushabhthakkar_910
Good Blogs Sir.... @SeeMSixty7
Thanks and Regards,
Rushabh Thakkar.
Please use the Accept Solution button to mark any posts that provide the answer or solution.
Likes are always welcome.
LinkedIn | Instagram | Facebook.
Message 8 of 10
GrantsPirate
In layout 1 you just need to pan the view to show the same area as layout 3.
You can set named views in MS with the VIEW command and then in a layout using the layout tab you pick the Insert View command from the ribbon and pick the view you want, then you can right click to pick a scale or you can place the view and then set the scale by picking on the edge of the viewport, pick on the drop down arrow in the middle of the viewport and selecting the scale.
GrantsPirate
EXPERT ELITE MEMBER
Message 9 of 10
TuesdayNightCo
Good to know, thank you. The VIEW command is new to me (super-noob) and that's a very useful basic command!
So there's nothing wrong with the way I'm doing it, then! Yay.
Message 10 of 10
BeKirra
Hi @TuesdayNightCo
I recall my previous posts when reading your questions.
Please have a look here
https://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/scale/m-p/5898463/highlight/true#M33...
https://forums.autodesk.com/t5/autocad-forum/my-text-is-too-small-how-do-i-increse-the-scale/m-p/588...
HTH
Please mark "Accept as Solution" and "Like" if my reply resolves the issue and it will help when others need helps.
A circle is the locus of a cursor, starting and ending at the same point on a plane in model space or in layout such that its distance from a given coordinates (X,Y) is always constant.
X² + Y² = C²
