Does anyone know if you can exclude items from being purged, or being 'suggested / listed' for purging, as it were?
I've looked around in settings, etc., but haven't seen anything myself.
Thanks.
Solved by gary.sutton9KV7N. Go to Solution.
PURGE dialog version,
Remove the checkmarks from your items?
(EDIT: Changed the img)
-PURGE commandline version
<It's more tricky, ask for it if needed>
Sebastian
To exclude items from being purged, only check the items to purge in the dialog box.
If the dialog box is missing, look into this link:
Please select the "Accept as Solution" button if my post solves your issue or answers your question.
Thank you both for your answers, however, I already know this, as it is elementary - I suppose how I should have framed my query is... 'how do I stop AutoCAD from suggesting them in the first place?' (I know that I could leave them in the drg. somewhere, so that they're being 'used' and won't be suggested for deletion, but suppose I didn't want that, but didn't want them on the purge list, all the same??)
>>"how do I stop AutoCAD from suggesting them in the first place?'"
Use them!
For example Layer: Create a Block with one object per layer, make sute your drawing file contains one blockreference of this block,
used objects can't purged, so they never offered to purge.
Sebastian
sorry, i didn't read the end of your post 🙄
You have "to use" them, but there are some more hidden ways to do that (in use, means that one or more pointers to this item, also non graphic objects can link to them).
If nobody is faster, I will post a sample later
Gary >>"Thanks again, for the sake of it, I'll close this discussion out."
Sebastian
