excel to autocad with vba
hello,
i tried to write a little code that takes text from excel table's cell and write it in autocad but still can't execute it.
Sub DrawAutocadline()
Dim AutocadApplication As Autocad.Application
Dim startline(0 To 2) As Double
Dim endline(0 To 2) As Double
Set AutocadApplication = CreatObject("Autocad.Application")
startline(0) = Cells(2, 2).Value
startline(1) = Cells(3, 2).Value
endline(0) = Cells(2, 3).Value
endline(1) = Cells(3, 3).Value
AutocadApplication.ActiveDocument.ModelSpace.AddLine(startline, endline)
End Sub
if someone can correct my code or suggest me another one i will be grateful.
Alfred.NESWADBA
What happens when you try it?
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
firts it shows me that my code is incorrect and i dont know how to handle this cuz am still new at this:
error compilation, expect =
thanks
Alfred.NESWADBA
Which code? Which line?
Please understand that we are not sitting behind you seeing what message you get!
Things like "not working" or "incorrect" without getting all the information you get on your display is not enough for us to reply with valid suggestions.
- alfred -
Alfred NESWADBA
hello,
yes i am sorry for not beeing clear 🙂
but i have resolved this problem thanks to a code that i think link autocad with excel, it works.
Sub Connect_Acad()
On Error Resume Next
Set acadApp = Interaction.GetObject(, "AutoCAD.Application")
'Set acadApp = Interaction.GetObject(, "AutoCAD.Application.22")
'both statements above behave without any discernible difference
If Err Then
Debug.Print "ERROR " & Err.Number
Debug.Print Err.Description
Debug.Print "starting autocad"
Err.Clear
Set acadApp = New AcadApplication
'Set acadApp = Interaction.CreateObject("AutoCAD.Application.22")
'essential statement
acadApp.Visible = True
If Err Then
MsgBox Err.Description
Exit Sub
Debug.Print "Now running " + acadApp.Name + " version " + acadApp.Version
Set acadDoc = acadApp.ActiveDocument
If acadDoc Is Nothing Then
Set acadDoc = acadApp.Documents.Add
If acadDoc.ActiveSpace = 0 Then
acadDoc.ActiveSpace = 1
End Sub
Call Connect_Acad
Dim lineObj As AcadLine
Set lineObj = acadDoc.ModelSpace.AddLine(startline, endline)
ZoomAll
End Sub
this is the code that works for me, thank you very much sir, i really appreciate your interest in helping me.
