"Walk and Fly" - Pop Up when panning or 3DOrbit without any solution
Heyho Community,
As the title says, my problem with AutoCAD is the pop-up window when I try to pan or 3DOrbit.
This post is kinda my last hope, since even the support couldn't help me right now and is still trying to find a solution.
Okay here we go:
This pop-up message is a bit strange in my case. It kinda appears random. It is not bound to working in viewports. It started to appear when I try to move around in larger 3D-Modells. In the beginning it seemed to help to just restart AutoCAD. Now it's only fixed via restarting the computer. It seems to appear in completely random drawings that aren't connected in any way. Also it appears "timely-random". Sometimes I have to restart my computer 2-3 times a day, and sometimes it doesn't occur for 2-3 weeks. This makes it difficult to locate the source in my case. It also occurs independently of using the middle mouse button, the command "3DOrbit" or the button for the command. Also it appears in any visual style except for the 2D-Wireframe and the Wireframe.
I'm using the raw AutoCAD 2020 version, without any application installed on top.
I already tried (with the support):
- Everything that is concluded in this article: https://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/warnin...
- updating the graphics card driver
- opening a new dwg (which leads to the same message)
- Change variable VSFACESTYLE
- Checking variable MBUTTONPAN (set to 1)
- reset settings to default
- changing my mouse (hardware) (I'm working with a "normal mouse" and no 3D-Mouse)
- My drawing was checked in the support enviroment by one of the support-employees
- Different Collegues tried opening my drawings and reproducing the error, which wasn't possible
- First appereance was in ACAD 2019, still occurs in ACAD 2020 which was installed after the first time it occured
- To exclude any hardware problems, in terms of not having enough memory-capacity we checked my setup (I will list my hardware setup below)
My Setup:
AutoCAD 2020.1.2
Windows 10
NVIDIA Quatro P5000 (certified driver)
128GB of RAM
Standard mouse (already changed)
I think I wrote down everything the support and I tried until now. Maybe one of you can provide me any other way to solve this problem.
Thanks in advance.
