Error when start Auto Cad
BBKENGJS
Message 1 of 12
BBKENGJS
This happen when open a new session of AC and then open any file.
After that if stay in the same session I can close or open any file without the error, but after closing AC and reopening AC the error showing again.
Replies (11)
Message 2 of 12
VincentSheehan
Just a few questions. Which version? Are you up-to-date on updates? Have you tried to reset AutoCAD?
Vincent Sheehan
Sr. Civil Designer
Poly In 3D Blog
Message 3 of 12
BBKENGJS
AC 2027 , but the same happening in 2026 and 2025. Yes I tried reset and the error is not showing, but I have partial customization files I want to use. So most likely the problem is in the custom .cuix . But how to find where?
Message 4 of 12
AllenJessup
Try opening a drawing with an OOTB Template. See if you still get the error in that file. If might be in your Template.
Can you post an example drawing so we can see if we get the same error?
Allen Jessup
CAD Manager - Designer
Message 5 of 12
pendean
Community Legend
Community Legend
@BBKENGJS Are you in or opening a DWG file from Plant3D for example? That might explain the failure across 2025-26-27 versions.
Share a sample troublesome DWG file here for others to try if and only if you are using plain AutoCAD (topic of this forum).
Message 6 of 12
BBKENGJS
I already try open from OOTB template. Still the same problem. But I notice that the same .cuix file do not generate the Error on different computer. So it's not a .cuix? Then what ???
Message 7 of 12
BBKENGJS
I using AutoCAD 2027-English
Message 8 of 12
Ed__Jobe
That message sounds like a database error. Do you have customizations that connect to a database on startup? Notice that the header is not an AutoCAD error.
Ed
How to post your code.
Message 9 of 12
BBKENGJS
Yes I have customization .cuix. But I reset the AutoCad and tried to run default install without any custom .cuix and I'm getting the same error. I tried also uninstalling and installing again fresh AutoCad and getting the same error.
Message 10 of 12
pendean
Community Legend
Community Legend
But your file is not, it contains elements from other variants of AutoCAD and you have corruption in the file.
Can you share that DWG file here?
Message 11 of 12
BBKENGJS
But it happening with any DWG file including the one created based on default template provided by AutoCad 2027 installator.
Message 12 of 12
lauri_barnhart
Hello @BBKENGJS, thanks for posting in the community!
Just checking in - has your issue been resolved?
If you've resolved this issue, please share it. It will help other community user find a solution to similar problems.
If not, please provide an update so other members can jump in with further suggestions.
Best,
Lauri | Community Manager
