Hi
We have an error message in AutoCAD, dose somebody knows why this message I appearing
Regards
Henrik
What causes this error message to appear?
Are you running any add-ins?
What version of AutoCAD are you using?
Have you tried starting AutoCAD in safemode?
Hi Paullimapa, Thangs for replying
The error message is appearing just random, not in any special cases, it is about 2 times a day.
Start appearing for one month ago.
Running AutoCAD 2024.
Regards
Henrik
First check About command window and make sure you’ve installed latest updates
You didn’t mention if you’re running any third party apps. Maybe there’s an add-on that’s triggering it
BlockEnder? What is that please?
What are you doing or which commands are you in when that occurs?
Basically, how do we follow along to replicate your issue in 2024?
HI
I do not use any third party apps
Have alle updates.
Just appearing out the blue.
If this error not coming from AutoCAD, it must be a problem wit windows I think.
Regards
Henrik
Definitely doesn't look like an AutoCAD error message. You should check all the programs you have running under Windows.
@Henrik_Lo wrote:...I do not use any third party apps
Have alle updates.
If this error not coming from AutoCAD, it must be a problem wit windows I think....
Do you have MATHWORKS or MATLAB / SIMULINK software installed on your PC?
Are you by chance using a vendor OEM version of AutoCAD? Not a purchase from Autodesk direct?
