AutoCAD Forum
Error in Custom Hatch - Need Help to Debug
2 REPLIES 2
486 Views, 2 Replies
Can anyone find an error in the following .pat file? I believe the coordinates are correct, it just won't read in AutoCAD 2011.
Thank you in advance!
2 REPLIES 2
hmsilva
Not tested, try adding a blank line at end of file
Henrique
Alfred.NESWADBA
in reply to: hmsilva
You have those two lines in your PAT:
0,  0,0,   0, 0,  10, -20, 20
90, 0,0,   0, 0,  30, -20
And you need at least one deltaX or deltaY, in both lines both of those values are 0.
The rest here works:
90, 0,0,   0,10,  10, -20, 20
90, 0,0,   0,20, -10,  30,-10
90, 0,0,   0,30,  20, -20, 10
90, 0,0,   0,40, -20,  30
0,  0,0,   0,10,  30, -20
0,  0,0,   0,20, -20,  30
0,  0,0,   0,40, -10,  30,-10
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2024
(not an Autodesk consultant)
AutoCAD Inside the Factory
