Hi @oronegro,
I suggest that we try to remedy this behavior by reinstalling the Application Manger using the following steps:
1. Verify that AAM is not running, check the system tray, if you see AAM running, right click on it and Exit
Note: Open windows task manger and if you see AdAppMgr.exe*32 and AdAppMgrSvc.exe*32 running under Processes, please End Process for both
2. Uninstall AAM from Control Panel
3. In Windows Explorer address bar type %USERPROFILE%\AppData\Local\Autodesk and hit Enter key
4. Rename .AdskAppManager folder
5. In Windows Explorer address bar type %USERPROFILE%\Documents\Autodesk Application Manager\ and hit Enter key
6. Double click on AdApplicationManager-installer.exe to install AAM
7. Once AAM is installed you may need to update it to the latest version.
John Vellek
