Error en Autodesk Application Manager
oronegro
Observer Observer
oronegro
Observer
Observer
No puedo abrir archivos desde el explorador de windows.
Espero puedan ayudarme.
john.vellek
I can not open files from Windows Explorer . I hope you can help me.
Hi @oronegro and welcome to the Autodesk Community.
What version of AutoCAD are you using? Can you open AutoCAD and then use file open to open your drawings?
John Vellek
oronegro
Observer
Observer
Gracias por contestar
Estoy usando la versión Autocad 2015 en windows 2010
Puedo abrir desde el Autocad cualquier archivo dwg, el problema es cuando intento abrir un archivo desde el explorador de windows.
Cuan hago doble click en el archivo desde el explorador sale el cuadro de dialogo adjunto.
saludos.
john.vellek
Hi @oronegro,
I suggest that we try to remedy this behavior by reinstalling the Application Manger using the following steps:
1. Verify that AAM is not running, check the system tray, if you see AAM running, right click on it and Exit
Note: Open windows task manger and if you see AdAppMgr.exe*32 and AdAppMgrSvc.exe*32 running under Processes, please End Process for both
2. Uninstall AAM from Control Panel
3. In Windows Explorer address bar type %USERPROFILE%\AppData\Local\Autodesk and hit Enter key
4. Rename .AdskAppManager folder
5. In Windows Explorer address bar type %USERPROFILE%\Documents\Autodesk Application Manager\ and hit Enter key
6. Double click on AdApplicationManager-installer.exe to install AAM
7. Once AAM is installed you may need to update it to the latest version.
John Vellek
john.vellek
Hi @oronegro,
I am checking back to see if my post helped you with your problem or if you need additional assistance or information. Please add a post with how you decide to proceed and your results so other Community members may benefit.
Please hit the Accept as Solution button if my post fully solves your issue or answers your question.
John Vellek
