error code 84026
error code 84026
error code 84026
Does anyone know how to fix error code 84026.
I drew an oblique frustum using the loft command. To cut an area of the frustum, i created an extruded circle and used the subract command but the error code pops out.
Ive tried it different times and redrawn the items but Im still having the same error.
Any help and will be much appreciated..
error code 84026error code 84026
imadHabash
your issue is noticed here in this AKN article , hope that LOFTNORMALS system variable will solve your issue . >> Click <<
Imad Habash
Thank you for taking time and for your effort.
I tried all the values for loftnormals but im still having the same error.
Jerome
Just move it to somewhere where you don't want it, that works for me, to form the piece wrong... thanks autocad
Did anyone ever give you a solution for this? I'm having the same problem at the moment trying to subtract (boolean) solids from a block, not at all complicated and getting the same error code.
I saw on other posts there were issues with the parts not intercepting but this is clearly not the case:
Garrett.Brothers
I'm getting the same error code when generating ortho views in Plant 3D.  Probably a completely different solution for me, despite the same underlying cause.
