Hi!
I´m using Autocad 2015 and Photoshop CS5.
I created, according to guidelines, an EPS Plotter (Postscript level 1), when i launch Plot command everythings go fine, i also see the preview of the plot.
Then i save the Eps file and it´s totally blank, the files´weight is always the same (7 kB) and when i place it into Photoshop ( or i open it) it´s alway empty..
Can someone help me?
Thanks in advance
Hi!
Thanks in advance
Solved by wkohn. Go to Solution.
try to uncheck your plot transparency from plot dialoge.
Imad Habash
Imad Habash
the "plot transparency" was already unchecked..
Having elements with transparency via layer can be the reason of empty EPAS files?
I just had this same issue. Turning transparency off in the plot settings or page setup might not do the trick. On a hunch I figured something was overriding that little checkbox. Turns out the variable "PLOTTRANSPARENCYOVERRIDE" was set to 2. I reset it back to 1 and my eps' are printing just fine now. Too bad I was two years too late on this post, but hopefully all you future readers are happy to have an answer.
I am on Autocad 2019 and this did not work for me. I can print to a pdf using DWG to PDF but I could not print to an EPS file. After distilling, the plot came out blank. It shows up fine in the preview but blank after distilling.
Try this (for Windows): go to Plotter Manager, choose the PsP2 (esp) plotter, go to Device and Document Settings Tab, go to the drop down menu of "Graphics", click on "Vector Graphics" , go and change the "Dithering". I changed it from "Hardware Pattern Order" to "Hardware Scatter Dither" . It did the job for me.
