AutoCAD Forum
Eldorado Stone Hatches are freezing AutoCAD 2016
27 REPLIES 27
Message 1 of 28
10005 Views, 27 Replies
I am using AutoCAD 2016.
I have tried multiple methods of importing a particular hatch pattern (European Ledge from Eldorado Stone) into AutoCAD.  It's there under my list of hatches, I'm able to do that just fine.  But when I do the HATCH command, any time I try to either 1) create a new hatch with this European Ledge hatch pattern, or 2) change an existing hatch to this European Ledge hatch pattern, the program just freezes.  Like the hatch pattern just freaks the program out and the program can't handle it.  And I have to force quit the program.
In other words, I can import the hatch pattern into my DWG file.  But I cannot actually use the hatch pattern because it freezes the program.
I tried turning HPDLGMODE to 1, and then hatching the object, but when I try that, the command line shows this:
Command: H
HATCH
Pick internal point or [Select objects/remove Boundaries]: Selecting everything...
Selecting everything visible...
Analyzing the selected data...
Analyzing internal islands...
Bad pattern definition file:
Missing parameter on line 4.
This seems to be a recurring problem with Eldorado Stone hatches.  Our company has not been able to import any Eldorado Stone hatches into AutoCAD for a while, so we have had to just use stone hatches that look different.
We can use our other hatch patterns.  But we cannot use the Eldorado Stone ones.
Any help would be appreciated.
27 REPLIES 27
Message 2 of 28
john.vellek
Hi @Anonymous,
I see that you are visiting as a new member. Welcome to the Autodesk Community!
It is difficult for me to download outside files. Is it possible to attach their PAT file or files so I can take a look?
John Vellek
Message 3 of 28
in reply to: john.vellek
Here is the PAT file I am working with.
Message 4 of 28
john.vellek
Hi @Anonymous,
Very strange that I used your PAT file without an error in AutoCAD 2017 and in AutoCAD 2016. I dragged it into my current drawing and then used Hatch to find a boundary and apply the  hatch.
I also don't see anything unusual in line four of the PAT file.
Perhaps there is something in your drawing that is corrupt and is preventing the pattern from being applied. Can you send me one of your drawings where you have tried the hatch?
John Vellek
Message 5 of 28
pendean
Works fine here in R2016
Message 6 of 28
hugha
in reply to: pendean
A long-standing requirement for AutoCAD hatch pattern definition was that all lines must be 80 characters or less in length - as stipulated here:
http://help.autodesk.com/view/ACD/2017/ENU/?guid=GUID-A6F2E6FF-1717-44B6-A476-0CA817ADD77E
The pattern in question has many lines that flout that rule -  the first of those being at the mentioned line #4. It appears that a pattern generator intended to create Revit hatch patterns (where line length is rarely a problem) was used to create that file.
You can easily shrink the line lengths to 80 characters or less by removing trailing zeroes.  Try this version:
;        Written by HatchKit Professional
;        HatchKit Professional (c)1990-2016 Cadro Pty Ltd
;        www.hatchkit.com.au/
;-Date                                   : 22/11/2016
;-Time                                   : 10:11:21 AM
;-HatchKit Version                       : 3.1.9.2674
;-HatchKit Output Filetype               : AutoCAD format
*European Ledge - Eldorado Stone,Cottonwood
90,20.875,0,0,-41.75,1.5,-12
90,17.75,3,0,-41.75,1.5,-12
90,19.313,1.5,0,-41.75,1.5,-12
90,38.625,3,0,-41.75,1.5,-12
90,40.188,1.5,0,-41.75,1.5,-12
90,11.875,4.5,0,-41.75,1.5,-12
90,8.75,7.5,0,-41.75,1.5,-12
90,10.313,6,0,-41.75,1.5,-12
90,41.75,0,0,-41.75,1.5,-12
90,29.625,7.5,0,-41.75,1.5,-12
90,31.188,6,0,-41.75,1.5,-12
90,32.75,4.5,0,-41.75,1.5,-12
90,0,0,0,-41.75,1.5,-12
90,14.875,9,0,-41.75,1.5,-12
90,13.313,10.5,0,-41.75,1.5,-12
90,32.625,12,0,-41.75,1.5,-12
90,34.188,10.5,0,-41.75,1.5,-12
90,35.75,9,0,-41.75,1.5,-12
90,11.75,12,0,-41.75,1.5,-12
180,41.75,1.5,0,-13.5
180,41.75,3,0,-13.5
180,41.75,4.5,0,-13.5
180,41.75,6,0,-13.5
180,41.75,7.5,0,-13.5
180,41.75,9,0,-13.5
180,41.75,10.5,0,-13.5
180,41.75,12,0,-13.5
180,41.75,13.5,0,-13.5
It is interesting that other users succeeded with the original pattern where OP did not.
hth,
Hugh Adamson,
www.cadro.com.au
Message 7 of 28
john.vellek
in reply to: hugha
Hi @hugha,
Interesting indeed!
I have even tried adjusting units precision but I am still able to use the hatch without error.
I am curious if the tabs (instead of spaces) after the comma delimiters have anything to do with this  behavior. If I find out more I will update the thread. Thanks for the catch!
John Vellek
Message 8 of 28
hugha
John,
it would be a good thing if Autodesk could relax AutoCAD's long-standing 80 character limit, the requirement that custom files contain a single pattern named to match the file, the requirement for an additional line at the end of the file and be tolerant of internal whitespace and linebreaks.  These are the little details most newcomers have some grief with.
80 character lines are a relic from the days of teletypewriters and punched card-readers 🙂
Looking forward to any light you may be able to throw on this.
Hugh
Message 9 of 28
in reply to: hugha
Thank you for this!
I opened the PAT file in Notepad and manually deleted all of the extra digits (such as deleting all the zeros from 41.750000000), then saved the file, then went into AutoCAD and tried to use the hatch, and it worked!  Thanks for the help!
(For the record, when I copied and pasted the version you posted hugha, the hatch didn't work in AutoCAD and I was given the error message "Bad pattern definition file: Missing parameter on line 29."
But when I went in to the original PAT file (after re-downloading it from Eldorado) and deleted the extra digits manually it worked perfectly).
Thank you for your help - I found a way to insert the hatch!
There is an additional (very small) problem which is a bit perplexing.  I can insert the hatch without a problem.  I can use MATCHPROP to change a hatch to and from this European Ledge hatch.  However, when I click on a hatched area, and go to the hatch drop down menu to change the hatch from another kind of hatch TO the European Ledge hatch, the program freezes (and I can press Escape to exit the command (and sometimes I have to press CTRL+Z to "undo", so the program doesn't crash, but I still can't change the hatch to this European Ledge hatch using this method)).  There are other workarounds such as MATCHPROP which is probably the most convenient, or just deleting the hatch and re-hatching it using the hatch pattern I want - but I was just wondering if anyone might know why the program is doing this and if there is a solution?  I will attach a DWG file in case anyone wants to take a look.  (Also, this problem is present regardless of whether HPDLGMODE is set to 1 or 2).
Again, in terms of functionality and productivity, I've found a solution - I was just wondering about this (small) confusing glitch in the program's hatch function in this case.  (The primary reason I am even asking about this very small problem is: I've found a solution for our entire office to be able to use the Eldorado hatches now, and solving this little glitch in the function could probably prevent a few hang-ups around the office in the future as people try to use these hatch patterns).
Thanks again for your help.
Message 10 of 28
scot-65
Try this condensed version.
For me, the pattern looked the same.
*EuropeanLedge
0.0, 0.0,0.0, 0.0,1.5
90.0,  0.0,0.0,     0.0,20.875, 1.5,-12.0
90.0, -1.5625,1.5,  0.0,20.875, 1.5,-12.0
90.0, -3.1250,3.0,  0.0,20.875, 1.5,-12.0
90.0, -6.0,9.0,     0.0,20.875, 1.5,-12.0
90.0, -7.5625,10.5, 0.0,20.875, 1.5,-12.0
90.0, -9.1250,12.0, 0.0,20.875, 1.5,-12.0
90.0, -9.0,4.5,     0.0,20.875, 1.5,-12.0
90.0, -10.5625,6.0, 0.0,20.875, 1.5,-12.0
90.0, -12.1250,7.5, 0.0,20.875, 1.5,-12.0
The Eldorado hatch did work here on 2016 as well.
Scot-65
A gift of extraordinary Common Sense does not require an Acronym Suffix to be added to my given name.
Message 11 of 28
Ok, I just ran into another problem.  For some of the hatches (such as European Ledge and LedgeCut33), I will be able to implement the solution of manually deleting all the extra 0's.  However, for most of them (Cypress Ridge, Fieldledge, Hillstone, Mountain Ledge, River Rock, RoughCut, Rustic Ledge, and Stacked Stone) I will not be able to.  Here is why.  Many of the lines of text go over 80 digits and can't be made shorter, because there aren't any extra 0's.  For example:
172.8749836511, 7.5189060041, 6.4417547617, 35.7220035617, 4.4652504452, 4.6556791424, -285.5855997964
5.1944289077, 20.8652916526, 4.0596174207, -35.8521554328, 3.2592868575, 3.0767667161, -394.5562299026
8.1301023542, 27.1058455759, 11.7995589907, -35.6381817718, 5.0911688245, 0.5003083536, -254.0581328736
Each of these lines goes over 100 digits.  So I will not be able to manually delete digits to get them under 80 digits.  In other words, as of now I have no way to use these hatch patterns that I listed.  Attached is an example DWG file as well as the PAT files for a couple of the hatch patterns I mentioned.  I am unable to use the following hatch patterns.  Does anyone know what the solution might be for this?
Thank you,
Michael Murrin
Edit: Also, does anyone know if it is possible to unmark this topic as solved?  The problem was solved only for a couple of the hatches (European Ledge, LedgeCut33), but for the other 10 or so Eldorado Stone hatches our office would like to use, it has not yet been solved.
Message 12 of 28
Sorry for the double post, but:
Right now the priority is figuring out how to use the Stacked Stone hatch pattern.  Attached is the PAT file.  When I try to use this hatch pattern, I get the message "Error in Pattern File".  Does anyone know what the problem for this might be?  I cannot shorten the number of digits per line, because many lines go over 100 digits and don't have any extra 0's to delete.
Also attached is an example DWG file.
Thanks for any help.
Edit: I just came up with another possible solution.  Since these hatch patterns are working perfectly for a number of people, is there any chance one of you could create a dummy file in AutoCAD 2016, hatch an area using the Stacked Stone hatch (as that's what I need right now), and then attach that DWG file to a post here?  I may be able to just save that file and then use MATCHPROP to get it to work. It may not work, but it's worth a shot.
2nd Edit: I figured out how to unmark the topic as "solved", as it is not yet solved.
The hatch patterns I would like to have the functionality of using, but currently cannot use for the reasons I have described in above posts and this post, are:
Stacked Stone (1st priority right now)
Ashlar
Cypress ridge
Fieldledge
Hillstone
Ledgestone
Mountain Ledge
River Rock
RoughCut
Rubble
Rustic Ledge
Message 13 of 28
hugha
Line 29? Try adding a blank line to the file following line 39 (the last line of the file) and it may come good.
best,
Hugh
Message 14 of 28
scot-65
Could it possibly be the [Tab] in lieu of blank spaces?
(or no spaces at all)
I would try that first.
Scot-65
Message 15 of 28
hugha
To shorten pattern lines, you can safely take precision from X and Y (the 2nd and 3rd items on each line). Then, very carefully, from other items.
Hatchkit does this automatically on output:
;-Date                                   : 23/11/2016
;-Time                                   : 10:11:19 AM
*Stacked Stone - Eldorado Stone,Eldorado Stone - Pagosa Springs
0,0,3.4359,0,-36,0,-36
0,0,28.5,0,-36,0,-36
0,0,11.712,0,-36,0,-36
0,0,20.25,0,-36,0,-36
0,0,0,0,-36,0,-36
0,0,24.25,0,-36,0,-36
0,0,7.6859,0,-36,0,-36
0,0,16,0,-36,0,-36
0,0,20.25,0,-36,36,0
0,0,28.5,0,-36,36,0
0,0,24.25,0,-36,36,0
0,0,16,0,-36,36,0
0,0,3.4359,0,-36,36,0
0,0,0,0,-36,36,0
0,0,7.6859,0,-36,36,0
0,0,11.712,0,-36,36,0
0,1.25,4.4359,0,-36,21.5,-14.5
0,7.75,10.061,0,-36,20.11,-15.89
0,15.912,32.5,0,-36,20.088,-15.912
0,19.612,35.054,0,-36,16.388,-19.612
0,3.3918,6.1359,0,-36,16.367,-19.633
0,3,10.887,0,-36,14.5,-21.5
0,20.613,17.364,0,-36,12.157,-23.843
0,20,0.73195,0,-36,12.375,-23.625
0,20.613,18.781,0,-36,12.157,-23.843
0,20.036,25.5,0,-36,12.349,-23.651
0,3.5,30.75,0,-36,12.412,-23.588
0,19.759,7.0046,0,-36,12.602,-23.398
0,24.178,22.136,0,-36,11.822,-24.178
0,1.721,17.573,0,-36,11.029,-24.971
0,12.928,21.636,0,-36,11.25,-24.75
0,25.593,33.458,0,-36,10.407,-25.593
0,6.0525,31.529,0,-36,9.86,-26.14
0,20.036,27.37,0,-36,9.4925,-26.5075
0,11.165,2.0825,0,-36,8.8467,-27.1533
0,4,21.636,0,-36,8.9281,-27.0719
0,3.3918,6.6859,0,-36,8.5861,-27.4139
0,4.5,19,0,-36,8.25,-27.75
0,27.86,9.2501,0,-36,8.1396,-27.8604
0,16.051,13.601,0,-36,8.1984,-27.8016
0,11.612,34,0,-36,8,-28
0,16.051,12.712,0,-36,8.1984,-27.8016
0,16.051,14.426,0,-36,8.1984,-27.8016
0,15.917,23.187,0,-36,8.2612,-27.7388
0,28.174,29.384,0,-36,7.8263,-28.1737
0,0.28676,26.441,0,-36,7.7132,-28.2868
0,12.75,18.125,0,-36,7.8633,-28.1367
0,28.174,30.25,0,-36,7.8263,-28.1737
0,15.912,30.5,0,-36,7.6928,-28.3072
0,12.75,16.683,0,-36,7.8633,-28.1367
0,0.28676,24.865,0,-36,7.7132,-28.2868
0,2.4711,32.577,0,-36,7.3785,-28.6215
0,7.8633,22.988,0,-36,7.4472,-28.5528
0,0.75488,8.9359,0,-36,6.9951,-29.0049
0,13.375,25.407,0,-36,6.661,-29.339
0,13.375,26.344,0,-36,6.661,-29.339
0,22.75,5.414,0,-36,6.5,-29.5
0,29.617,2.0913,0,-36,6.3835,-29.6165
0,29.528,27.004,0,-36,6.4715,-29.5285
0,13.375,27.25,0,-36,6.661,-29.339
0,21.12,9.4504,0,-36,6.74,-29.26
0,9.8496,32.577,0,-36,6.0628,-29.9372
0,24.249,14.277,0,-36,6.2051,-29.7949
0,19.612,33.596,0,-36,5.9814,-30.0186
0,24.249,12.553,0,-36,6.2051,-29.7949
0,10.128,14.75,0,-36,5.9224,-30.0776
0,5.4154,2.0825,0,-36,5.75,-30.25
0,-0.007093,33.75,0,-36,6.0037,-29.9963
0,9.9479,13.214,0,-36,6.1028,-29.8972
0,30.454,13.838,0,-36,5.5458,-30.4542
0,8,27.094,0,-36,5.375,-30.625
0,5.9966,33.75,0,-36,5.6155,-30.3845
0,20.203,5.914,0,-36,5.5816,-30.4184
0,0,1.936,0,-36,5.3422,-30.6578
0,0,2.7319,0,-36,5.25,-30.75
0,23.162,30,0,-36,5.0112,-30.9888
0,30.887,23.25,0,-36,5.1128,-30.8872
0,4.7009,13.006,0,-36,5.2469,-30.7531
0,20,2.3414,0,-36,4.9414,-31.0586
0,0,13.838,0,-36,4.7009,-31.2991
0,5.3918,14.512,0,-36,4.7365,-31.2635
0,0.45091,14.327,0,-36,4.25,-31.75
0,31.921,10.75,0,-36,4.0793,-31.9207
0,23.848,30.742,0,-36,4.3261,-31.6739
0,0,23.25,0,-36,4,-32
0,0,22.136,0,-36,4,-32
90,24.178,20.25,0,-36,4,-32
90,20.036,24.25,0,-36,4.25,-31.75
90,15.912,28.5,0,-36,4.077,-31.923
90,8,24.25,0,-36,4.25,-31.75
90,11.978,3.4359,0,-36,4.25,-31.75
90,32.771,16,0,-36,4.25,-31.75
90,20.613,16,0,-36,4.25,-31.75
90,12.75,16,0,-36,4.25,-31.75
90,32.36,3.4359,0,-36,4.25,-31.75
90,16.051,11.712,0,-36,4.2877,-31.7123
90,24.249,11.712,0,-36,4.2877,-31.7123
0,32.36,6.412,0,-36,3.6396,-32.3604
0,0.75,18.75,0,-36,3.75,-32.25
0,27.86,10.875,0,-36,3.8438,-32.1562
90,27.86,7.6859,0,-36,4.0264,-31.9736
90,7.75,7.6859,0,-36,4.0264,-31.9736
90,28.174,28.5,0,-36,4,-32
90,4,20.25,0,-36,4,-32
0,32.36,5.1096,0,-36,3.6396,-32.3604
0,24.871,31.854,0,-36,3.3022,-32.6978
0,25.79,2.3276,0,-36,3.4597,-32.5403
0,32.771,18.25,0,-36,3.2295,-32.7705
90,11.612,32.555,0,-36,3.4454,-32.5546
90,20,0,0,-36,3.4359,-32.5641
90,19.612,32.5,0,-36,3.5,-32.5
0,-0.011036,6.6859,0,-36,3.4029,-32.5971
0,0,9.9359,0,-36,3,-33
0,0,5.9359,0,-36,2.9917,-33.0083
0,0,10.75,0,-36,3,-33
90,13.375,24.25,0,-36,3,-33
90,29.25,2.3276,0,-36,3.0864,-32.9136
0,3.9912,22.846,0,-36,3.2588,-32.7412
0,32.753,16.959,0,-36,3.2472,-32.7528
0,29.726,4.9382,0,-36,2.6346,-33.3654
90,30.454,11.712,0,-36,2.5646,-33.4354
90,4.5,17.573,0,-36,2.6772,-33.3228
-63.4349488229,31.721,2.0401,48.299068314,16.099689438,2.2698,-78.22864719
90,12.626,28.486,0,-36,2.2643,-33.7357
90,0.45091,13.783,0,-36,2.2172,-33.7828
90,0,33.458,0,-36,2.5417,-33.4583
90,21.12,7.6859,0,-36,2.375,-33.625
11.309932474,1,30.25,35.3009043249,-7.06018086496,2.5495,-181.015202489
0,0,32.577,0,-36,2.4711,-33.5289
0,3.5,31.529,0,-36,2.5525,-33.4475
90,0.28676,24.25,0,-36,2.1912,-33.8088
90,29.528,25.5,0,-36,1.8699,-34.1301
90,23.162,28.5,0,-36,2,-34
90,34.021,20.25,0,-36,1.8858,-34.1142
90,30.887,22.136,0,-36,2.1142,-33.8858
45,23.605,30.5,25.4558441227,25.4558441227,1.915,-48.9966882454
-26.5650511771,0,5.1096,48.299068314,-16.099689438,1.5065,-78.99194719
-26.5650511771,0.75,18.25,48.299068314,-16.099689438,1.4907,-79.00774719
90,3,9.9359,0,-36,1.7764,-34.2236
-45,2.4711,32.577,25.4558441227,25.4558441227,1.4816,-49.4300882454
90,1,28.5,0,-36,1.75,-34.25
-63.4349488229,32.286,25.5,48.299068314,16.099689438,1.3979,-79.10054719
90,10.128,14.512,0,-36,1.4882,-34.5118
90,8.1458,11.712,0,-36,1.2933,-34.7067
90,29.617,0.73195,0,-36,1.3593,-34.6407
90,19.759,6.1359,0,-36,1.5499,-34.4501
90,27.249,14.277,0,-36,1.7231,-34.2769
90,32,33.458,0,-36,1.5954,-34.4046
90,31.921,9.2501,0,-36,1.5,-34.5
90,32.61,7.6859,0,-36,1.5643,-34.4357
90,4.7009,12.827,0,-36,1.5,-34.5
90,22.75,4.4359,0,-36,1.4782,-34.5218
0,-0.00914,17.134,0,-36,1.7302,-34.2698
90,16.25,16.683,0,-36,1.4424,-34.5576
90,27.14,16,0,-36,1.3639,-34.6361
90,9.9479,13.006,0,-36,1.5062,-34.4938
90,12.928,20.25,0,-36,1.3858,-34.6142
90,15.311,21.636,0,-36,1.3526,-34.6474
90,11.165,2.0825,0,-36,1.3533,-34.6467
90,29.771,18.781,0,-36,1.4688,-34.5312
90,18.06,20.242,0,-36,1.3935,-34.6065
90,22.362,33.596,0,-36,1.4574,-34.5426
90,1.721,15.985,0,-36,1.5883,-34.4117
90,0,27.004,0,-36,1.496,-34.504
90,6.7399,15.985,0,-36,1.5883,-34.4117
90,0,9.2501,0,-36,1.5,-34.5
90,0,5.1096,0,-36,1.3024,-34.6976
90,0,1.936,0,-36,1.4998,-34.5002
90,0.88123,18.75,0,-36,1.5,-34.5
63.4349488229,4.7904,0.83253,48.299068314,-16.099689438,1.3975,-79.10094719
0,0,29.384,0,-36,1,-35
-63.4349488229,31.857,27.004,48.299068314,16.099689438,1.1807,-79.31774719
90,12.035,22.988,0,-36,1.2616,-34.7384
90,1.1437,23.25,0,-36,1,-35
90,4.4161,6.6859,0,-36,1,-35
90,25.593,32.5,0,-36,1.0962,-34.9038
90,5.9966,32.577,0,-36,1.173,-34.827
90,26.306,24.231,0,-36,1.2696,-34.7304
90,29.286,27.37,0,-36,1.1298,-34.8702
90,15.917,23.187,0,-36,1.0632,-34.9368
90,15.049,27.25,0,-36,1.25,-34.75
0,0,18.25,0,-36,0.75,-35.25
-26.5650511771,0,9.2501,48.299068314,-16.099689438,0.84398,-79.65446719
-26.5650511771,25.106,2.6699,48.299068314,-16.099689438,0.7654,-79.73304719
90,0.35909,6.6859,0,-36,1,-35
90,25.784,5.914,0,-36,1.0906,-34.9094
90,0.75488,7.6859,0,-36,1.25,-34.75
90,22.827,11.712,0,-36,1,-35
90,1.25,3.4359,0,-36,1,-35
63.4349488229,4.1437,11.712,48.299068314,-16.099689438,1.2459,-79.25254719
63.4349488229,24.901,27.356,48.299068314,-16.099689438,1.2796,-79.21884719
63.4349488229,24.941,2.3414,48.299068314,-16.099689438,1.2237,-79.27474719
0,0,30.25,0,-36,1,-35
-26.5650511771,19.759,6.1359,48.299068314,-16.099689438,0.49616,-80.00228719
-28.0724869359,29.25,2.3276,80.4705882353,2.11764705889,0.50267,-611.49733
-45,29.25,5.414,25.4558441227,25.4558441227,0.67287,-50.2388182454
-50.9061411138,27.86,7.6859,230.505858035,-1.74625650014,0.87748,-741.281532611
-63.4349488229,17.029,11.712,48.299068314,16.099689438,0.92318,-79.57526719
90,28.424,32.5,0,-36,0.95825,-35.04175
-26.5650511771,31.585,10.875,48.299068314,-16.099689438,0.37427,-80.12417719
-52.1250163489,25.784,5.914,179.972305562,-3.15740886951,0.63451,-409.828643036
-63.4349488229,0,27.004,48.299068314,16.099689438,0.63164,-79.86680719
-63.4349488229,5.25,2.7319,48.299068314,16.099689438,0.72598,-79.77246719
90,17.5,10.061,0,-36,0.82572,-35.17428
90,20.075,13.601,0,-36,0.82444,-35.17556
90,3.5,30.75,0,-36,0.77936,-35.22064
90,32.75,28.5,0,-36,0.88369,-35.11631
90,0.75,18.25,0,-36,0.5,-35.5
90,4.7904,0,0,-36,0.83253,-35.16747
90,26.178,-0.0085548,0,-36,0.7405,-35.2595
90,3.3918,6.1359,0,-36,0.54995,-35.45005
90,5.25,2.7319,0,-36,0.70401,-35.29599
90,31.704,10.875,0,-36,0.83717,-35.16283
90,32.385,25.5,0,-36,0.44771,-35.55229
63.4349488229,24.871,31.854,48.299068314,-16.099689438,0.72216,-79.77628719
26.5650511771,2.9917,5.9359,48.299068314,16.099689438,0.44734,-80.05110719
14.9314171781,4.7007,14.327,148.413686723,-2.31896385495,0.71527,-558.155019065
12.9946167919,7.2497,22.847,331.892631887,-2.69831408029,0.62973,-479.670176309
18.4349488229,15.312,22.985,34.1525987298,-11.3841995766,0.63806,-568.57191883
make sure to include an additional line when copying the above.
Hugh
Message 16 of 28
john.vellek
Hi @Anonymous,
I found this compiled lisp routine (attached). I used it to export the pattern I was able to use (and you weren't). It seems to have compressed the lines down nicely.
Give it a try and let me know if the PAT file works for you now. If so, I would be happy to try it on another pattern for you if you want to attach it.
John Vellek
Message 17 of 28
@john.vellek ,
Thank you!  This pattern worked.
Would you be able to try it with the attached Stacked Stone pattern?
As I mentioned, unfortunately there are a number of other patterns I am unable to get to work.  In addition to your method, I had found a solution as suggested by hugha to fix the European Ledge and LedgeCut33 patterns, but for reasons described in an earlier post, I was not able to fix any of the other patterns.  I don't want to mark the topic as "solved" yet so as not to decrease traffic to it, until all of the problems I listed have been solved.  But when I do I will mark every post that gave me a solution to one (or all) of the problems (including your post here) as the solution.
Also hugha and scot-65, I will try your suggestions as well.  Thank you.
Message 18 of 28
hugha
@john.vellek wrote:
... I used it to export the pattern I was able to use (and you weren't).
Hi John,
Any further on why some users (such as yourself) are able to load that Revit pattern as-is to AutoCAD while others cannot?
best,
Hugh
Message 19 of 28
john.vellek
in reply to: hugha
Hi @hugha,
I have been looking internally but have not found any other documentation.I am unable to use the stacked stone pattern in AutoCAD 2017 and still trying to find a solution for the OP.
So far the only solution I have to offer is to export the pattern from Revit.
John Vellek
Message 20 of 28
hugha
Ashlar
Cypress ridge
Fieldledge
Hillstone
Ledgestone
Mountain Ledge
River Rock
RoughCut
Rubble
Rustic Ledge
These patterns can be sourced directly from Eldorado Stone:.
http://eldorado.webcubecms.net/trade-community/specification-library/hatch-patterns/
Some are very large but all should be able to be loaded to AutoCAD without further editing as their line lengths are <= 80
hth,
Hugh
Forma Design Contest
AutoCAD Beta
