Education Resources - 2d to 3d
lee.pellegrin
Message 1 of 8
lee.pellegrin
I would like to know of a few good resources to use to learn how to work in the 3D aspect of autocad. I have been mostly working with Lt in a 2d enviroment for years, and I am now modeling in autocad.
Replies (7)
Message 2 of 8
imadHabash
@lee.pellegrin
>> ... to learn how to work in the 3D aspect of autocad.
It depends on a combination of things... starting with self-learning, experimenting with commands, and reading help (F1). Then watching videos online... and of course, going back here to the forum and asking what's holding you back.😊
Imad Habash
Message 3 of 8
lee.pellegrin
Well, for starters, when I run the vport command, and select NEw, I am not able to rotate in model space to define my view. I have to unlock the viewport, rotate, and move to where I want to be. My current process is cumbersom and I would like to streamline it. I have thought about creating a named view and bringing it in that way, but I am not sure if there is a better way than those two methods?
Message 4 of 8
imadHabash
what is your final AutoCAD result that you want to reach?
Imad Habash
Message 5 of 8
lee.pellegrin
Final result is to create a viewport without using mview.
Message 6 of 8
imadHabash
You said
I am not able to rotate in model space to define my view." ..... Model space command.
create a viewport without using mview." ..... Layout space command.
Still your issue not clear yet ?!! 🤔
Imad Habash
Message 7 of 8
TheCADnoob
I'm not sure i understand the problem. Venturing a guess, you can choose one of the standard rotated views when creating your view port.
When you are creating a new view you have to change the setup to 3D
Once you do that you can select all the standard views
If you have multiple viewports you click black box areas to select the viewport and you can select an independent view for each.
That said if you want a custom view that is what named views are for.
CADnoob
Message 8 of 8
lauri_barnhart
Hello @lee.pellegrin, we appreciate you posting your question.
Did the information provided by TheCADnoob help?
If this helps, feel free to accept it as the solution.
This helps other users benefit from the shared solution.
If the issue persists, let us know with an update so we can assist further.
Lauri | Community Manager
