I am working on some drawings that have the same title block, but need different individual titles and page numbers within this block. My issue is when I try to change a drawing/layouts title or page number, all the other layouts titles or page numbers change, as well. Does anyone know how to fix this, so editing one title block does not edit every title block?
Thank you,
Aaron
Solved by kasperwuyts. Go to Solution.
The definition of a block is stored in the DWG itself.
If you have two different DWG drawing files, and if you have the 'Title block' - block (for lack of a better term) in both of them, and change it only in one of the drawing files, then it won't change inside the other DWG. However, if you don't change the name of the block definition, then copying the blocks between those drawings won't work. It will always use the block definition that is already stored inside the DWG you copy it to. So it is definitely best practice to rename a block if you edit it.
To Autocad, there's not really a difference between renaming a block and recreating it entirely. There is also a 'save as...' option inside the block editor which lets you copy the block definition inside the DWG under a different name.
So if today is a lazy day in which you rather do some repetitive brainless work instead of learning a few things about attributes, you could just copy the block definition for each layout under a different name and change it accordingly.
