Editable Attributes ...or... not?!
MarkFitz
MarkFitz
Good morning folks,
I'll get right to the point.  I have a drawing a border with editable attributes, i.e. the title block.  Everything seems to work just fine.  I go to insert it, again, everything LOOKS fine, but when I click on it, it says this block has no editable attributes.
Help?
Please?
Mark
imadHabash
I suggest to use ATTSYNC command in your bad block.
Imad Habash
pendean
Community Legend
Community Legend
Is it a block within a block now? A common mistake when trying to reuse something that's already a block. Explode it once and find out if it remains intact and now editable.
qnologi
MarkFitz
Dean,
It does.
So I basically double blocked it?
Does a single "explode" correct this, or does it affect other things too?   i.e. whenever I get into this situation, is "single explode" the answer?
And yes, now that you've mentioned it, the "block within a block" phrase does sound familiar.
Cheers Dean!
Mark
MarkFitz
ATTSYNC just told me the same, that the block has no editable attributes - unless I'm using this command improperly, of course...
