DYNMODE NOT WORKING
DYNMODE NOT WORKING
Message 1 of 9
DYNMODE NOT WORKING
I AM NEW TO AUTOCAD . I RECENTLY DOWNLOADED A TRIAL VERSION OF AUTOCAD ARCITECURE 2018.N STARTED STUDYING. AND I FIND OUT THE DYNMODE IS NOT WORKING. EVEN IT SAYS DYNAMIC MODE IS ON. I DONT KNOW WHAT TO DO.
Replies (8)
Message 2 of 9
pendean
Community Legend
Community Legend
How do you think it is not working exactly?
Message 3 of 9
When I click on the dynamode it says on but it doesn't shows up on the cursor
Message 4 of 9
imadHabash
HI,
dynmode can be turned on by F12 and the icon at the status bar and try to set DYNMODE system variable to 3. also there is some settings that you need to check through DSETTINGS command > Dynamic Input tab.
Command: DYNMODE
Enter new value for DYNMODE <3>:
please confirm that the previous three ways are failed ?
Imad Habash
Message 5 of 9
Alfred.NESWADBA
What are you expecting to see on the cursor?
When you don't start any command and so you get questions from AutoCAD (to input a distance or a coordinate or to enter options for a command workflow) you won't see anything.
When you start typing, then you'll see your input close to the cursor position - as long as the cursor is inside the drawing area!
Try to type
_LINE
and you'll see that:
When you then type <ENTER> to start the line command, it asks you for a point or coordinates, that looks like that:
Do you see that?
If not please start the same steps and show your screen as screenshots here.
HTH, - alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2026
(not an Autodesk consultant)
Message 6 of 9
I did but still doesn't show the anything close to the cursor
Message 7 of 9
When I reset all still doesn't work
Message 8 of 9
1.pngYou should right mouse click in icon dynmode like picture then you choose setting. You check and click all. Good luck
Message 9 of 9
Alfred.NESWADBA
your setting of DYNMODE is 2, try 3.
If that also don't help try to reset settings to default as described >>>here<<<.
- alfred -
Alfred NESWADBA
