Message 1 of 18
- Mark as New
 - Bookmark
 - Subscribe
 - Mute
 - Subscribe to RSS Feed
 - Permalink
 - Report
dynatic text block text cilck copy after text paste {\{\urtf1\ansi\ansicpg65001\deff0\deflang1033{ this text fail?
How are you copying the information? Are you clicking copy or using a keyboard shortcut?
This string "{\{\urtf1\ansi\ansicpg65001\deff0\deflang1033{" is some form of text formatting.
Can you provide screen shots?
CADnoob
Any reason for not using the standard Copy command?
If want in another dwg how about wblock the text from dwg and then insert block exploded in the other dwg ?
DWG AND VİDEO ADDED @paullimapa @TheCADnoob
Test2: Please try the same in another Dialog, like STYLE [New...] copy the Style name and paste it..
same issue?
Sebastian
yes
Just guessing:
Are you running AutoCAD FOR MAC or AutoCAD (for windows) on MAC, or by remote?
If not: Perhaps you are using special settings for the system text (fonts, size, etc.),
but I have no idea about these possible connections,
this is just a wild idea.
Sebastian
Windows 10 Pro for Workstations pc computer
What AutoCAD version?
Run About command, do a screenshot and share that here
Oh you’re on the wrong forum
you should post here:
https://forums.autodesk.com/t5/autocad-plant-3d-forum/bd-p/371
SAME 3D AND 2021. IT DOESN'T MATTER
ADDING VİDEO
THX
Problem could be this 2021 is the original release with none of the updates applied
see version list here
This might be either a P3D issue or a 2021 wit no updates installed issue, I can copy paste just like in your video in plain AutoCAD 2023 just fine here
But this one is multi-line, aka MTEXT, and it may have overrides
Although, again, it copy/pastes just fine in AutoCAD 2023
And then... when I open and do the same in P3D 2023.0.2 (aka fully updated) I also have no issues
So you either need to make an effort to update your 2021 software
https://manage.autodesk.com/products/PLNT3D?version=2021&platform=WIN64&language=EINT
Or upgrade to a newer P3D?
I cannot duplicate your problem.
For some reason, it is copying the RFT formatting from the textbox control in the Attribute dialog.
when you enter the text editor, however, you are not interacting with a textbox control, so it doesn't copy the RTF.
Have you added any clipboard modifications to your system? Do you have any plugins installed in AutoCAD?
CADnoob
That's a fantastic Find! Thanks for sharing
CADnoob
