Trying to stretch line work not blocks. Can someone tell me if Dynamic Input works with the stretch command? I know that it works with grips, but only by picking a single grip.
If this can't be done, can it be done with a LISP?
Solved by pendean. Go to Solution.
>> I know that it works with grips, but only by picking a single grip. <<
if you have multi line stretch works you can select more than grip under one stretch command by Shift + select mouse button .
>> If this can't be done, can it be done with a LISP? <<
STRETCH command didn't work without selecting objects . so you have to select either by Grips or other ways ( Crossing,Window and fence .. ) . please tell us more what exactly you want to do ?
i could have sworn that i was able cross window and stretch line work by just typing in the new length. My DYNMDODE Setting are at 3. As i mentioned before i know how to use it with grips. I don't want that. Was just wondering if there are settings that i'm missing.
