Dynamic block with attribute and field not working from tool palette
- Mute
- Permalink
- Report
I am running into trouble trying to figure out how to get my custom dynamic blocks to work properly when inserted from a tool palette. Let me clarify by saying I am only having trouble with one particular type of dynamic block.. all the others are working just fine when inserted via tool palette.
This block would be for something like a kitchen cabinet where I have a rectangle with stretch properties for width and depth. I tell the block (via properties or grips) how wide and deep I want it to be.. then the block generates to size. Now inside of this block I also have an attribute with fielded text. The field is tied to the rectangle or "linework" dimension.. so when I change the size of the cabinet the notes inside update as well (12" x 24", 24" x 36", etc..). I use attributes so I can change the text to say things like (B. Cab., W. Cab., Pantry, etc..)
The blocks are working like magic.. I have used them for several months now with no issue. The problem I'm having is when this custom dynamic block is added to a tool palette, upon inserting the block I get this message 'see message in attachments below' and those automatic fielded dimensions are not populating.. I just get the xxxxx's. My work around is to use a template file that has all the dynamic blocks pre-loaded.. the fielded dimensions work perfectly when inserted that way. Any idea on what I could do differently to get this block to work via tool palette?
Much appreciated,
- Cody
