Hi there,
I have a dynamic block text where I insert from a tool pallet and it has a scale visibility state. When I insert the block and change the visibility scale I have to run an explode command to edit the text manualy.
I'm trying to make it so when I insert the block, I can select the visibility state and have it automatically explode at the end so I can edit the text right away. I have tried running a macro but It won't let me do a macro for visibility selection. It will only let me do an explode at the end of an insert.
I have attached the block and I hope someone here can help me with this.
Thank you.
@Anonymous,
john.vellek has edited your subject line for clarity: Dynamic block with
