Dynamic block Visibility State from Tool Palette
Hi there,
I have a dynamic block text where I insert from a tool pallet and it has a scale visibility state. When I insert the block and change the visibility scale I have to run an explode command to edit the text manualy.
I'm trying to make it so when I insert the block, I can select the visibility state and have it automatically explode at the end so I can edit the text right away. I have tried running a macro but It won't let me do a macro for visibility selection. It will only let me do an explode at the end of an insert.
I have attached the block and I hope someone here can help me with this.
Thank you.
@Anonymous,
john.vellek has edited your subject line for clarity: Dynamic block with
Accepted solutions (3)
john.vellek
Hi Peter,
I haven't found a way to prompt for visibility from a palette either. I have often times just put the block on the palette more than once with each instance set to the visibility state I want. Then I add a text label to help my users know which one is which.
Please hit the Accept as Solution button if my post fully solves your issue or answers your question.
John Vellek
yes, that is how I have it currently setup. Unless I can do a lisp would probably be helpful without having a dynamic block insert. All I'm trying to do is reduce the size of my tool pallet so its more simplified when inserting the text.
john.vellek
Hi Peter
I have not seen a routine that does this but it might be worth your time to explore the Customization forum to search for some solutions.
John Vellek
