I'm using 2018...
How do I dxb plot it like on the left?
Both are solid models...
Solved by Kurt.F6YL3H. Go to Solution.
try to change your visual styles setting? and see if helps. thanks
I've tried everything I know...
Of course, I tried the method you suggested...
But it doesn't work...
can you share the file?
can you try to dxb this file and see if helps. thanks
Example1 says there is no external reference file.
I plotted it in a dxf file...
I think the situation got worse...
Before plotting to a DXB file, make these settings:
Set sysvar DISPSILH to 1
Set sysvar FACETRES to 10
Set viewport property Shade plot to "Legacy hidden"
Should then look like this:
