AutoCAD Forum
dxb plot
9 REPLIES 9
Message 1 of 10
buddda72
500 Views, 9 Replies
dxb plot
제목 없음.pngI'm using 2018...
How do I dxb plot it like on the left?
Both are solid models...
9 REPLIES 9
Message 2 of 10
ennujozlagam
in reply to: buddda72
try to change your visual styles setting? and see if helps. thanks
Message 3 of 10
buddda72
in reply to: ennujozlagam
I've tried everything I know...
Of course, I tried the method you suggested...
But it doesn't work...
Message 4 of 10
ennujozlagam
can you share the file?
Message 5 of 10
buddda72
Message 6 of 10
ennujozlagam
can you try to dxb this file and see if helps. thanks
Message 7 of 10
buddda72
Example1 says there is no external reference file.
I plotted it in a dxf file...
I think the situation got worse...
Message 8 of 10
pendean
you will need to manually clean it up (as it appears you have done already). Sorry.
Message 9 of 10
Kurt.F6YL3H
Before plotting to a DXB file, make these settings:
Set sysvar DISPSILH to 1
Set sysvar FACETRES to 10
Set viewport property Shade plot to "Legacy hidden"
Should then look like this:
Message 10 of 10
buddda72
in reply to: Kurt.F6YL3H
Thank you, buddy...
You solved the problem...
State of Sustainability Webinar
AutoCAD Inside the Factory
