AutoCAD Forum
DWL File location
6 REPLIES 6
jamied2000
5131 Views, 6 Replies
DWL File location
Is there a way to have the DWL file be in a different file location than the drawing location?  I am wondering because we just started a PDM system and whenever I crash it does not get rid of the DWL file in the PDM.  So in order to get this removed from the PDM i have to contact my PDM administrator to remove it.
6 REPLIES 6
dwl and dwl2 files are automatically created by Autocad and are used to determine if the drawing is open, or information if the drawing has crashed.  There is no way to change where they get created.
Christopher T. Cowgill, P.E.
Civil 3D Certified Professional
Civil 3D 2022 on Windows 10
Ok thank you.  I was thinking that but just wanting to make sure.
imadHabash
in reply to: jamied2000
since these are hidden system files, i suggest to set your folder options accordingly in Windows Explorer and hide this option. in this way you will not observe them again .
Imad Habash
Unless you have a system where AutoCAD never crashes, I wouldn't recommend hiding the .dwl files: that would lead to situations where the .dwg file is locked against editing, with no easily discoverable way to notice the reason.
in reply to: chriscowgill7373
Hi
is there any way to prohibit that the dwl´s are created?
thanks in advance!
S.Faris
MAKE A BACKUP FIRST - BUT MAINLY DON'T DO THIS IF YOU DON'T KNOW WHAT YOU ARE DOING
According to this article
1. Move WhoHas.arx to another folder not in AutoCAD's search path.
2. Edit the Registry by deleting the key HKEY_LOCAL_MACHINE\SOFTWARE\Autodesk\AutoCAD\R21\ACAD-xxxx:yyy\Applications\AcadWhoHas.
SALMANUL FARIS
AutoCAD Inside the Factory
