.dwg to .stl, incorrect construction of the model.
dm0144
Message 1 of 10
dm0144
I have two questions here.
I have a problem when I export Autocad Model into a .stl file. The model is not completely and correctly constructed (as seen on the screenshots 124 and 125 below). I had the same problem with similar models but I tried to move them, copy-past them into different drawing and somehow it worked, they got constructed correctly but with this model, I have tried everything, even using Autocad 2014 and it did not work. Every time I tried to export it, the model was incorrectly constructed. In Fusion 360 I did not have that problem but then I had a problem with 3D printing the model.
Since we are at the same model I have one more short question.
Is it possible in Autocad 2018 to select one profile and to sweep it to multiple paths at once so I do not have to do it manually for every single path which is a very time consuming, especially for making my model (screenshot 123)?
Best regards,
Daniel.
Replies (9)
Message 2 of 10
S.Faris
Try increasing the FACETRES value(max value is 10) and see if that corrects the issue with the model
SALMANUL FARIS
Message 3 of 10
imadHabash
you may need to check the units of your drawing.
You can sweep more than one profile object along a path.
Imad Habash
Message 4 of 10
S.Faris
Regarding "select one profile and to sweep it to multiple paths at once".
Try the attached LISP file
Source : Sweep along multiple paths
SALMANUL FARIS
Message 5 of 10
dm0144
Thank you for your response
I increased the FACETRES to 10 and it did not make any difference, again incorrect construction of the model.
Also at the end of the exporting process, I get note above the command bar saying:
''The Boolean operation on solid and/or surface bodies failed.''
''Modeling Operation Error.''
''Error Code Numer is 84030'', as you can see on the screenshot.
Message 6 of 10
S.Faris
I believe one or more of your 3d elements have some errors, which results in this. Can you upload the file here?
SALMANUL FARIS
Message 7 of 10
dm0144
@S.Faris  this is the dwg model.
Message 8 of 10
dm0144
  • Also regarding ''sweep along multiple paths'' I uploaded the LISP file and the only difference was that the profile was not deleted. Even though I tried to select multiple paths, it only chose one to sweep along and not all.
Message 9 of 10
S.Faris
I checked your file and tried to UNION 5-10 solids at a time and found 2 solids with some errors. the remaining were pretty much good. I am attaching the file here. You can see 2 red colored solids which gives error while Union. try re-modeling those 2. I also tried to 3D print the Union object and it was successful. If I tried to include the 2 solids with error. then the print came out with errors.
SALMANUL FARIS
Message 10 of 10
S.Faris
As I can see in the commandline, You are still using the sweep command. Loading a Lisp does not modify your existing command. it brings in new. In this case the command is MSWEEP. Learn more on LISP loading and running here.
I had checked the LISP file before uploading it here and it works just fine.
SALMANUL FARIS
