@imadHabash wrote:
i suggest to follow this AKN article ....
That [about DVIEW] will help if a 3D model is built. If a 2D-constructed perspective is required, DVIEW is of no use. It is certainly possible to lay out a perspective in AutoCAD, in the same way you do on paper [draw a horizon line, establish vanishing points, rotate the plan for the viewing angle and establish the viewer's eye location and a reference line relative to the plan, project all sorts of lines from there to points on the plan for their intersections with the reference line, set a height for the perspective where the plan meets the reference line, cast lines from various points to the vanishing points, etc., etc.]. It's only a matter of doing the same things electronically that you would do on paper. As already suggested, presumably you have a textbook or something that describes how to go about that -- it would be quite a chore to try to spell it all out for you here.
Kent Cooper, AIA
