DWG to PDF.pc3 issues
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Just recently I started having issues with dwg to pdf.pc3
I used to be able to right click on my model tab, select plot, select dwg to pdf.pc3, ANSI full bleed B (17.00x11.00 Inches) , Fit to paper, click okay and it would generate a pdf that was able to be edited. Now when I do all that, it generates as PDF but when I go to edit that, it changes it into an Image! I have researched everything, and I cannot find a solution to get it to go back to the way it was, because I HAVE to be able to edit the PDF.
I am using Autodesk AutoCAD 2023.
