DWG to PDF converter
Martin.PetricCTC4Q
Martin.PetricCTC4Q
I am looking for a DWG to PDF converter, which would automatically convert DWG drawings with XREFs into PDFs. Is there a way to automatically set some features in AutoCAD to do that?
Or do you I need a separate converter, which would do that for me (price is less, features, simplicity and reliability are most important)?
The issue is, it takes my whole day to convert DWGs to PDF, plus binding every Xref makes the process slow and doesn't allow me to do something in the meantime.
Thanks for your help!
BR, Martin
imadHabash
In AutoCAD .. you can use PUBLISH (Command) and after preparing a page setup .
In AutoCAD .. you can mange it by ETRANSMIT (Command) .. >> Click <<
Imad Habash
Martin.PetricCTC4Q
Thank you for your immediate response and at the same time thank you VERY MUCH for the solution :)!
This helps me a lot!
RobDraw
You don't need to bind XREFs just to make PDFs.
Rob
markcesene
Community Visitor
Community Visitor
If you are looking for a tool that can help you to convert your AutoCAD files into PDF and various other file formats. You can go with the DRS AutoCAD DWG Converter Tool. It is the best DWG file converter to change your AutoCAD files into PDF, JPEG, BMP, TIFF, DOC, HTML, PNG, and GIF formats. While changing the file format, the application maintains file integrity. Moreover, the application is a fast and compact tool for all versions of Windows OS.
