I am trying to convert dwg to jpg. When I select all in layout view then enter COMMAND - JPGOUT I get the title and text but not the drawing. I've tried doing this in Model view i.e, select all - COMMAND - JPGOUT, I can view the drawing this way however, I need everything to be together in layout view. Can anyone offer advise on this please. I've attached two images fyi.
Solved by john.vellek. Go to Solution.
"Otto" is the "person" to whom you replied in post 4.
I figured your post 4 reply was in response to the totally inaccurate answer that "Otto" gave in post 2.
Hi @Anonymous,
Otto is a help bot, which attempts to use natural language in the initial post to provide answers very quickly to common questions on this board. We are in the process of gathering feedback and updating its recognition's. I have noted the error here and submitted the changes necessary to cause it to not respond in the way it did based on the context of your post.
Please refer to @pendean's post for a much more relevant answer in this case.
Hi @Anonymous,
I think the prompt for this command might be a bit confusing. When I am in paperspace I type JPGOUT. If I type All it gives me everything in paperspace. If I just hit a return after typing JPGOUT then it gives me everything in paperspace and the viewport contents.
>> When I type JPGOUT in Layout View
Repetition: have you seen/read post 3 here from @pendean, he clearly states this command is meant for model-space only, not for layout!
Plotting is the best and most efficient method to get layouts exported as raster file.
- alfred -
>> Yes, I totally understand what Dean was saying
>> I was responding to another comment in regards to JPGOUT.
Well, what am I missing?
You know from @pendean that JPGOUT does not work for layouts, but you again ask "When I type JPGOUT in Layout View I see only my Titleblock and Text" ...? Why asking again when you already have got the answer that this can't work?
- alfred -
Hence the inherent problem with the default flat presentation of messages in this forum. Without quoting the post, it's difficult/impossible to tell who someone is replying to, then misunderstandings happen.
@Anonymous - FYI: you can change your forum settings so that you can see the threaded progression (see image below), which I like. But I don't like that it only shows one post at a time, and clicking to show other posts takes forever (it requires a page reload). So I stick with the flat thread display.
And of course, many (maybe most) people here don't understand threaded messages and just click the [REPLY] button at the top of the page, regardless of the message to which they are replying. In that case, the threads don't have much meaning anyway.
