DWG Icons Blank in Windows Explorer
jlaidle1
Message 1 of 11
jlaidle1
DWG's are set to the 'AutoCAD DWG Launcher', but some of our users still have their DWG icons displaying blank.
John Laidler
ITO - Application Management
Please use "Accept as Solution" & give "Kudos" if this response helped you.
Accepted solutions (3)
Replies (10)
Message 2 of 11
Jonathan3891
You may have to re-associate the default program for dwg files.
Right click file > Open With > Choose Default Program > Choose AutoCAD.exe or whatever you're using.
Jonathan Norton
Blog | Linkedin
Message 3 of 11
jlaidle1
We have that set for 'AutoCAD DWG Launcher'.
John Laidler
Message 4 of 11
what happens if your users try to open one of the dwgs?
1. By double clicking in windows explorer
2. By 'open' command in AutoCAD
Once they have a drawing open, does the icon show?
It's possible that they just don't have the icon stored on their machine for some reason.
Here's an article for how to change a filetype icon in windows 7, 8 & 10 (requires additional free software to make the changes) https://www.maketecheasier.com/change-file-type-icon-in-windows/
Message 5 of 11
harrison7JJX7
This is a little off. I solved this issue by doing the following:
Right Click on any .dwg file > Properties > General Tab > Change the "Opens with" from "Unknown App" to "AutoCAD DWG Launcher" > OK
That worked for me.
Message 6 of 11
britneyVTKSU
Community Visitor
Community Visitor
This did not fix the issue.
Message 8 of 11
I used this method to correct the icon file location. This issue occurred after install autocad 2022 and remove 2021. The icon location remained as 2021 folder. So edited with FileTypesMan software.
Message 9 of 11
jayadinash
Observer
Observer
That did not work.
Message 10 of 11
facturasFE4UU
Changing the default app from the context menu didn't work for me but doing the same  from Windows Settings > Aplicactios > Default Apps sorted out the issue.
Message 11 of 11
biancab
Observer
Observer
That worked, thank you!
