AutoCAD Forum
dwg files bewteen MAC and PC
4 REPLIES 4
1567 Views, 4 Replies
I am planning to learn autocad but use a mac. I was going to download the free month to see how it goes. If I create files through the MAC version can those be easily opened in a pc version of autocad and updated, modified, etc.? I do not want to have to buy a pc if possible. Thanks
4 REPLIES 4
Patchy
DWG is the same
pendean
DWG files are seemless between the two platforms:no special action needed to swap files between them.
john.vellek
Hi @Anonymous,
Yes, as @pendean and @Patchy have indicated, the drawing format is identical between platforms.  You could run into little speed bumps though if you use some features on the Windows version to modify your drawing files.  Certain features that are included in the Windows version (Object Enablers, OLE, and more) are not supported on the Mac.
I suggest that you try to use the Trial to test how this would function in your workflow to see if things go smoothly.  I use both the Mac and Windows versions on the same files and have virtually no issues.
John Vellek
john.vellek
Hi @Anonymous,
I am coming back to your thread to see if the issue or question you posed has been resolved.  If so, please mark the post or posts as Solution(s) to help others find the answer quickly. If your issue persists, please give me a bit more detail on this issue so we can continue to work towards getting this solved.
John Vellek
Forma Design Contest
AutoCAD Beta
