AutoCAD Forum
Dwg File not opening up
4 REPLIES 4
1845 Views, 4 Replies
A dwg file I was working on is not opening up and it does not allow me to close the program either. Please help.
4 REPLIES 4
imadHabash
>> A dwg file I was working on is not opening up and it does not allow me to close the program either. <<
i suggest to try RECOVER command from empty new dwg and see if it's works , if not .... would you please attache here your dwg for testing ? also you can force AutoCAD to close from Ctrl + Shift + Esc then select AutoCAD from applications tab then press end task .
Imad Habash
pendean
john.vellek
Hi @Anonymous,
I see that you are visiting as a new member to the AutoCAD forum. Welcome to the Autodesk Community!
In addition to the suggestions by @imadHabash and @pendean, can you tell me where the file originated and which version of AutoCAD you are using?
If you like, you can attach your file to a post (and maybe its BAK file too) so I can a take a look. If it needs to remain private you can email it to me directly at john.vellek@autodesk.com
John Vellek
rkmcswain
I had a situation this morning that would appear to be related to the data file, but it was actually because of a 3rd party tool being loaded into AutoCAD.
The drawing required this tool to display certain objects, but the tool had a problem.
So, don't always assume the data file is at fault. Try to open the drawing on another PC, one that is pure stock with no add-ons if possible.
R.K. McSwain     | CADpanacea | on twitter
Forma Design Contest
AutoCAD Beta
