Is there a way of isolating drawings objects, linetypes, test styles, layers names & block names to allow a streamlined alignment to a new drawing standard. This work involves weeding thru a single dwg file, made up of 100+ dwg files with over 250k entities?
I have already used layer filtering to isolate & assign new layers to most entites but there are too may falling thru the cracks.
Any thoughts are welcome.
Solved by SteveChing4507. Go to Solution.
You can't isolate linetypes or text styles or layer-names or block-names.
It sounds similar to what I have to avoid purging such items ... I create a block, with lines on the layers I don't want to be purged, with linetypes I don't want to be purged, creating text objects with text styles I don't want to be purged and insert the blocks inside my "nopurge" block, that should not be purged. If you have such a block you can use _WBLOCK to export all you need from the current dwg-file to create standards from that.
Is that what you are looking for?
- alfred -
