AutoCAD Forum
DWFATTACH doesnt work
6 REPLIES 6
BSchwartzkopf
549 Views, 6 Replies
I am trying to attach a 3d DWF to an autocad file and I get an error everytime I try to attach it . I am new to the DWFATTACH command so I am sure its something I have done but I do not know what.
6 REPLIES 6
imadHabash
in reply to: BSchwartzkopf
Audit,Recover and Purge (Reg) commands will help to clean your file.and make sure that your dwf file format match your AutoCAD version.
Imad Habash
BSchwartzkopf
in reply to: imadHabash
I do not think that is it because I am trying to attach it into a brand new drawing. I think it is something in the dwf. Will autocad not let you attach a 3D plant layout that is a dwf?
imadHabash
what i mean in my first post is to do it for the origin CAD file and before preparing dwf file.
Imad Habash
BSchwartzkopf
Oh I do not have access to that file since it is from an outside vendor and it is an Inventor file natively.
imadHabash
>> since it is from an outside vendor and it is an Inventor file natively. <<
then you have to contact them and describe your problem.or try to use the most new AutoCAD version 2018 if available (as a try).
Imad Habash
john.vellek
HI @BSchwartzkopf,
Can you share the DWF with me? I would like to see if I can attach it in any of the versions of AutoCAD I am currently running.
John Vellek
AutoCAD Inside the Factory
