AutoCAD Forum
Dual monitor setup with AutoCAD 2020/tabs
40 REPLIES 40
Message 1 of 41
ScottRoth
47785 Views, 40 Replies
Just got a second monitor for the purpose of having two tabs open at the same time to work on two drawings with only one session of ACAD2020 opened using windows 10. Being a novice at this setup, not sure if/how possible. I have the display setting at "extend these displays" under multiple displays. I can open separate sessions of AutoCAD in each monitor (workaround) and can have multiple tabs in each monitor opened. I want to be able to open 1 session with a separate tab opened on each monitor.
I can do this with MS products (excel) by opening the program and multiple tabs, then dragging one of the tabs over to the other monitor. This process doesn't work with AutoCAD though...
Is this possible? If so, how is this done??
Thanks in advance,
- Scott
40 REPLIES 40
Message 21 of 41
ScottRoth
in reply to: elie.accari
Thank you. Finally found someone understanding my issue! Guess will just have to wait for autocad to get up to speed with revit.
Message 22 of 41
chandler
Being able to do this in Revit has lead me here lol
Thanks for clearing that up!
Message 23 of 41
nrz13
in reply to: ScottRoth
AutoCAD 2022 has added the functionality to drag windows out of the main program window.  Look up the SYSFLOATING command.
Work:  AutoCAD 2022.1.3, Windows 10 Pro v22H2 64-bit, Intel Core i7-8700K, 32GB RAM, Samsung 960 Pro SSD, AMD Radeon Pro WX 5100, 3 Dell Monitors (3840x2160)
Home: AutoCAD 2022.1.3, Windows 10 Pro v22H2 64-bit, Intel Core i7-11700, 64GB RAM, Samsung 980 Pro SSD, NVIDIA Quadro P2200, Dell Monitor (3840x2160)
Message 24 of 41
ScottRoth
in reply to: nrz13
Wow, thanks - did not know that. I'm still using 2021 version but when I make the swicth will make note of that command. Thank you!
Message 25 of 41
elie.accari
What nrz13 said.
Message 26 of 41
csalvian
That still doesn't achieve a true multiple monitor setup though. The dream is to have one file: model space open on the left monitor, paper space (or multiple paper space views) open on the second or third monitor - make a change in model space, see the change reflected in the sheet view in each of the paper space views.
Message 27 of 41
elie.accari
in reply to: csalvian
interesting, in my case if i'm working on sheet view, i persoanlly prefer one monitor and i toggle/ use:
chspace
mspace
pspace
or double click in and out
Message 28 of 41
ВeekeeCZ
Don't get too excited (as I did), the feature is useless (as found later). Hopefully, it's just a first step and the feature would be further developed and enhanced in the future.
Message 29 of 41
jrreid
Your monitor settings I am sure is correct.  Your problem is you need to upgrade to AutoCAD 2022. They call it Floating Drawing Windows - Drag a file tab off of the AutoCAD application window, creating a floating window. This makes it easy to move the drawing to another monitor. No other versions of AutoCAD allowed this. I used to open (2) sessions of AutoCAD to do what this does now so easily.  It works great and this is how it looks:
Hope this helps!
JRR.
Message 30 of 41
csalvian
in reply to: jrreid
I've seen that feature and, please correct me if I'm wrong, it still doesn't accomplish what I described. Yes, it lets you pull a different drawing file off the tab and let it float outside the main drawing window, but it still doesn't let you pull the SAME drawing file out just with a different view: one paper space, one model space. Similar to how, in Excel, I can have two sheets within the same file open, so that if I make changes in Sheet1, it automatically updates the results in Sheet2, which references Sheet1.
Message 31 of 41
nrz13
The equivalent of your Excel example would be to have your model space in one drawing, then x-ref it into your layout drawing.  Then you can have both views open at the same time on two separate screens by pulling one or the other out. Now, it's not real-time updates, but you could use a keyboard shortcut to refresh the layout regularly. Real-time pushes to referenced drawings would be a handy improvement.
Message 32 of 41
csalvian
That still doesn't update automatically though, which is what Excel does. Other than AUGI with their wish list, does Autodesk have a feature suggestion area? I haven't seen anything on their websites.
Message 33 of 41
RobDraw
What you are asking cannot be done on one monitor. How can you expect it to work on more than one?
Rob
Message 34 of 41
Alfred.NESWADBA
Yep: >>>Autodesk Product Feedback<<<
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
Message 35 of 41
csalvian
in reply to: Alfred.NESWADBA
Well that's an incredibly not useful feedback page. When I click "Submit" I get a 403 Forbidden website error.
Message 36 of 41
Alfred.NESWADBA
For me it worked a time ago (and have not gotten a feedback like yours whenever I recommended it), have you tried a different browser?
- alfred -
Alfred NESWADBA
Message 37 of 41
jonathancaTZ46T
OPEN 2 SESSIONS OR GET THE 2024 VERSION WHICH COMES WITH THAT FUNCTION.
Message 38 of 41
nrz13
in reply to: jonathancaTZ46T
As already noted above, this was added in the 2022 version.
Message 39 of 41
csalvian
Ok, this post is a little outdated, but I was able to get AutoCAD to do what I wanted it to do (kind of). It will definitely give you the idea of what the functionality is that would probably be useful to a large number of people that use multiple monitors, because the ability to pull another FILE out of the drawing window (which is what is currently implemented in AutoCAD 2024) is NOT this:
Re: Spanning multiple monitors - Autodesk Community - AutoCAD
Message 40 of 41
ccanada_global
I first clicked the restore down button on my launched AUTOCAD app, then manually resized the Autocad window to fit one AUTOCAD window in 2 monitors. Just drag the edges of the app towards the end to end of the 2 monitor.
Hope this helps
AutoCAD Inside the Factory
