Dual monitor setup with AutoCAD 2020/tabs
ScottRoth
Message 1 of 41
ScottRoth
Just got a second monitor for the purpose of having two tabs open at the same time to work on two drawings with only one session of ACAD2020 opened using windows 10. Being a novice at this setup, not sure if/how possible. I have the display setting at "extend these displays" under multiple displays. I can open separate sessions of AutoCAD in each monitor (workaround) and can have multiple tabs in each monitor opened. I want to be able to open 1 session with a separate tab opened on each monitor.
I can do this with MS products (excel) by opening the program and multiple tabs, then dragging one of the tabs over to the other monitor. This process doesn't work with AutoCAD though...
Is this possible? If so, how is this done??
Thanks in advance,
- Scott
Replies (40)
Message 2 of 41
user181
With your drawings open hit the restore down button in the upper right of the screen and you can size the drawing windows how you want them.
Message 3 of 41
ScottRoth
User181,
My problem is I can't drag a tab or window into the second monitor.
Message 4 of 41
user181
You would need to use the restore down above that one for the cad program and stretch the autocad window onto both monitors and then move the drawing windows around.
Message 5 of 41
cadffm
Your ONE Autocad window 50% on the left and 50% on the right monitor now?
Then do the same with your file windows inside acad.
Upper right area (of the right monitor) you will find the same icons for the current file window.
Change the second..
OR USE COMMAND: SYSWINDOWS
Upload a screenshot of both monitors, so we can see what  you seeing.
Sebastian
Message 6 of 41
pendean
Community Legend
Community Legend
You need to expand the single AutoCAD program session across both screens, then click on the VIEW tab in the Ribbon, select TILE VERTICALLY button on the Interface panel.
See Vid https://www.youtube.com/watch?v=hoFnbyYYgWc
Message 7 of 41
ScottRoth
I have one session opened on the left monitor. If I reduce the window size and try to drag to the right monitor it only appears on the right in a reduced window in a reduced image. If I open full screen it only appears in the left monitor. I know I'm doing something wrong but don't know what?
Excuse my noviceness <g>
Message 8 of 41
ScottRoth
pendean,
Sorry, but "how" do I expand one session over both screens?
(btw, the video is in another language and not really addressing what my question is, thanks though)
Message 9 of 41
ScottRoth
Cadffm,
No: "Your ONE Autocad window 50% on the left and 50% on the right monitor now?"
I can't get one session to show on both screens - so this isn't correct:
Message 10 of 41
pendean
Community Legend
Community Legend
>>>...I can't get one session to show on both screens...<<<<
Then you did not set up dual screens correctly to be one-streched-across-two-monitors in Windows: post a screenshot (not using your phone) of your dual-screen setup in Windows please.
Message 11 of 41
ScottRoth
Message 12 of 41
cadffm
Your first picture shows: All right there! except your DPI and resolution settings.
From state of the first picture: Stretch the program window to the edges,
then start the command SYSWINDOWS.
HTH
Sebastian
Message 13 of 41
pendean
Community Legend
Community Legend
Message 14 of 41
dgorsman
Going to back all this up for a minute, to cover a few basics.  All drawing windows must exist inside the application window.  If you have multiple AutoCAD sessions running, each can have its own set of drawings open, and they are within the appropriate parent application window.
Each drawing has multiple layouts, usually shown as tabs.  Any active drawing can only show one one layout at a time i.e. you cannot display both the model space and a paper space layout of a given drawing at the same time.
There are a couple of ways to cheat this, but usually more work than they are worth.  The more common method is to open another AutoCAD session with a read-only version of the drawing.
If you are going to fly by the seat of your pants, expect friction burns.
"I don't know" is the beginning of knowledge, not the end.
Message 15 of 41
Hi! If you are using a Windows system, try opening one of your cad file. Once it's open, find the Autocad App in your desktop or in the start apps section, right click the icon/app then click "Run as administrator" then open a file on that window. Then you have 2 operating Autocad XD
Please let me know if you have an alternate solution for this.
Please click the "Accept as Solution" button if I solve your issue or answer your question.
Message 16 of 41
ScottRoth
I can get to the point of having two different acad sessions open separately in each monitor. My original question was if it is possible to have multiple sheets open (tabs) and then grab one tab (sheet) to the other monitor to see it. Apparently I can't.
In other applications such as MS office (excel) etc, I can grab a tab/file and drag it onto my other monitor and it opens separately there.
I guess I have to manually open each file separately in each ACAD session that is open on each monitor - so no go on dragging across the the separate session of ACAD?
Message 17 of 41
pendean
Community Legend
Community Legend
At the moment, through R2021, you cannot do what you wish for.... .
Maybe in R2022-25-30.
Message 18 of 41
sascari
2020 and AutoCAD can't do multi-monitor support... That should tell you all you need to know about Autodesk
Message 19 of 41
cwr-pae
Since at least 2007 and through 2013, MS office programs (Excel and Word to be exact) do not use tabs for multiple files, they open separate instances of the program windows. Test it, open a file, reduce the window to less than full screen but not minimized, open or create a 'new' file. You have two program windows. Excel gives added tabs as the bottom for added sheets, but these remain in the original file and file window. Autocad still use the old multiple file tab paradigm or the single drawing interface (sdi=1) similar to MS Office.
Message 20 of 41
elie.accari
Just a note that in Revit 2020 you can take a tab and drag it outside the Revit windows.
In previous revisions, Revit people had to use t he same t rick described here: stretch the Revit app across two monitors then tile the sheets and work here and look there. Autodesk spent the R&D and fixed this for Revit but not for AutoCAD.
As it stands today: it is a feature in Revit but not a feature in Autocad, you have to use a work-around.
